Old 06-07-2009, 02:03 PM
SoundReplay SoundReplay is offline
Lightbulb At which sampling rate are you recording?
Say you have a PT HD system with a 192i/o.
How have you configured your session for your next live recording? The end product will be for CD media (44.1 kHz 16bit)
1) Are you using the stereo mixer (default) or the dithered stereo mixer?
2) Recording at 44.1, 48, 88.2 or 96 kHz?
I am recording at 88.2 kHz with the stereo dithered mixer plugin.
And you?
Thanks!
www.soundreplay.com
Old 06-08-2009, 04:29 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: At which sampling rate are you recording?
I track at 44.1 kHz and 24 bits, mix using dithered surround mixer
Janne
Old 06-09-2009, 08:05 AM
Extreme Mixing Extreme Mixing is offline
44.1/24 bit for me. If it's for video, it's usually at 48. I think it's best to stay with the sample rate that it will be in the end.
Steve
Steve Shepherd
Extreme Mixing
Old 06-09-2009, 09:44 AM
Rubicon's Avatar
Rubicon Rubicon is offline
Hi!
48kHz 24 bit. I think it sounds a little better and gives the plugs a little more to work with. If I work at a higher rate VI's become impossible. I am concerned that my 44k bounces sound a little different than the 48k sessions however. I also BTD, which is seriously old school.
Rubicon
Wikipedia
IMDB
ITunes
ML 10.8.2, PT 10.3.1 HD Accel 3, Mac Harpertown 32gb Apple RAM, 4 1T Apple Drives, Waves Mercury. Lots of unstable VI's.
Old 06-09-2009, 03:17 PM
AchimHamburg AchimHamburg is offline
24/44.1 here. Sonic quality is fine for commercials, any vo stuff, pop/rock music.
It seems to me that not having to convert from 48 to 44.1 sounds better than having to deal with the conversion process. Barbabatch does a great job here though. Might be some esotheric experience
When producing very subtle stuff (classical music etc) I track at 96. Just to have the quality for future use.
HD2 Mac Pro Quadcore OS X 10.5.6 PT 8.0
Old 06-09-2009, 03:29 PM
Exactly. Converting sounds worse that just working at 44.1 the whole time. Plus, you have to convert every rough mix along the way.
Steve Shepherd
Extreme Mixing
Old 06-09-2009, 06:47 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
the conversion from any sampling rate to any other sampling rate is not an issue. What is an issue is the FIR filter different programs use when doing conversion. The more precise the filter, the better the conversion sounds, but the longer it takes to process and to some extent, the more complex it is to code/write.
Here' a very interesting comparison if you haven't seen it already,
http://src.infinitewave.ca/
Just because one program sounds like crap when converting, has nothing to do with the conversion itself, and everything to do with the design of the filter they used. As you can see some programs have TONS of aliasing while others have none.
But... plugins and any other digital processing you use on your audio WILL sound better at a higher sampling rate. But it usually requires twice the processing power... so that is the trade off.
I use the analogy of recording video. In some ways it parallels audio in that, if you start with a higher resolution picture, your final low res output will look better than if you video-taped the whole thing in low res to begin with. If you don't believe me, watch a home movie you record...then watch something like Star Wars Episode 1 on VHS or on a non-HD TV channel. Star Wars looks better, doesn't it? Why is that? All the processing, visual effects and color correction done to the High resolution version makes for a better output to lower resolutions. Most recently Digital Video has started being shot at 4K and is converted down to 1080p/i after color correction.
While the process is totally different, the same basic concept holds true for audio. The higher the sampling rate and bit depth, the better all the processing will sound. So when you finally do SRC and dither down to 44.1/16, the fidelity is higher than if you recorded at 44.1/16 throughout the whole process.
Old 06-09-2009, 11:42 PM
DrFord's Avatar
DrFord DrFord is offline
Plus, as taught to me by Bob Ohlsson, most all professional converters are built optimized at 48k multiples. He then said that you will hear a more measurable difference in sound recording from 44.1 to 48 then you will going from 48 to 96.
The proof is in the recording though, as all of these factors are dependant on the quality of your converters in the recording process.
Crap in = Crap Out.
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 06-10-2009, 03:14 AM
I agree! The question remains if 88.2kHz would be your choice if your final product will be CD (44.1kHz), just because of the easy re-conversion (dividing by 2, rather than 2.1768... if you use 96 kHz)
I can clearly hear the difference between 44.1 and 88.2, but I can't hear any difference between 88.2 and 96.
Also, I believe that when tracking a big project, the summing of all your tracks might be better in 88.2 than 44.1.
These days, processing power or diskstorage should not be an issue, right?
www.soundreplay.com
Old 06-10-2009, 03:18 AM
So what you are saying is that fe. a 192i/o might produce better sound quality at 96 kHz than 88.2 kHz. But what about the re-conversion than to 44.1kHz. Will this sampling rate conversion not alter your sound more than tracking on 88.2kHz?
Actually, besides the number of available voices and track count, Digidesign is not suggesting anything in their manuals on this topic.
If convertors are capable of capturing audio at very high sampling levels, why not using them?
www.soundreplay.com
Anybody know what the max sampling rate of PT 8.0 LE is? Fabb2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2012 10:58 PM
16k sampling rate? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-31-2007 03:03 AM
mbox sampling rate madincraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2003 11:16 PM
Mbox sampling rate madincraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-03-2003 02:49 PM
Sampling rate changes using same stationery Walt Bob Pro Tools TDM Systems (Mac) 1 03-07-2001 10:51 AM
