Bluetooth and Instability?
Can use of an Apple bluetooth keyboard and mouse cause this kind of problem? My Mix system is comically unstable some days, with a half dozen kernel panics and unexpected Pro Tools quits in a single session. I have tried the usually suggested items of trashing databases and prefs, and repairing permissions. What I have not done, though, is to eliminate use of bluetooth. Turning off bluetooth is often mentioned as necessary by some.
I also worry that part of the instability may relate to use of a Gefen Cat 5 usb extender that permits remote placement of a bluetooth transmitter/receiver. It's this bluetooth usb adapter that ties in with the bluetooth mouse and keyboard. Thanks, John Caldwell
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Re: Bluetooth and Instability?
No problems with Bluetooth here but if you are having lots of problems, it is best to eliminate absolutely everything you can to narrow down the problem. Disconnect absolutely everything you can and start adding things to see if anything makes it worse. Good luck finding the problem.
- Jason |
SSD 4 and instability | nozzles | macOS | 2 | 01-23-2012 07:28 AM |
instability & lock-up problems - HELP! | Sydes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-11-2008 05:46 AM |
Instability of 7.3 | midi sordino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-13-2007 05:35 AM |
General instability in PT7, looking for help. | deafguy | Pro Tools TDM Systems (Mac) | 12 | 04-30-2006 11:02 AM |
System Instability With DR-008 | Amerihudge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-27-2003 11:15 AM |
