#2381
Re: Best Laptops for PTLE
Hey Folks,
This thread is so old there is no reason to read all of it. So forgive me if I step out of bounds here. The Express 34 is no longer available in MBP 15 inch portable. Also. If you have the new 17 in MBP. Report if TI firewire is present. Please. dpclat.exe is a non-privileged app you could run off a thumb drive. Just under 1000us stock - non tweaked is generally ok for clean DAW work. Tweakheads. Start with the Broadcom NIC card apparently this may cause spikes as does wifi (turn off in device mgr) as well as Bluetooth advertisements. Video camera also a spiker. Here's a chart a tweaktown to peruse interrupts which cause clicks and pops download dpclat.exe at post # 2 http://forums.tweaktown.com/f69/dpc-...x58-ud5-30547/ good hunting. |
#2382
PelicanWord, this laptop of yours, HP dv6-2170us 15.6, do you use a firewire device or usb?
I myself have a HP dv 6 1101so with W7 and PTLE 8.0.3 cs1 works fine with usb but with my 002r I have some issues. It has not a TI firewire card so I guess that's the problem.
https://www.facebook.com/petermartinssongroup/ |
#2383
If that's the i5 HP DV6, unless production has changed. It's a Ricoh chipset. I just checked device mgr. Download RicohProToolsEnabler.exe (from Digi's site) Sony i5 also a Ricoh. Unfortunately the fleabag (me) attempted to check the new MBP 17 inch also but no information present in system profiler but Firewire 800. They have been known to abandon TI also. This was at a store with no admin privileges. I have never seen device mgr lame like this. No drop downs arrows. Nada. It also appears Lenovo has removed their firewire port. End of story. Everyone. Download THESYCON's dpclat.pdf and dpclat.exe time to a' start tweaking.
#2384
What do you guys think about this baby? Huge power, has expresscard slot, so it is able to get a 3rd party firewire card.
TOSHIBA Qosmio X500-11W specs: Mobile Intel® Core™ i7 Mobile I7-720QM 2800 MHz 8192MB DDR3/1066 MHz - PC3-8500 564GB 64GB SSD + 500GB 7200 RPM SATA Intel® HM55 Express chipset NVIDIA® GeForce GTS 360M 1GB DDR3 VRAM http://laptops.toshiba.com/laptops/qosmio Do you think it will work with pt?
my blog:Tamas Dragon |
#2385
I just wanna use a laptop for edit/mix.........and the cheapest laptop so far I have found is a Toshiba for $999.......but ( there's always a but ) It comes with windows 7 (there's that trick bag again)......anyway to get usb to firewire adaptor for my Lenovo.....which is powerful enough AND came with win xp (that's why I bought it) I have a return exception with newegg but time is running out if I can't solve it.....any help here.
#2386
padraic, I have a DELL XPS 1340 (Studio 13 XPS) and although I'm new to PT 8 and the MBOX2, I already have it installed on a custom desktop. I will be installing on my XPS within a few days and will let you know how it performs. Should be good, but we'll see. eSATA and 1394 built in, kind of nice.
#2387
My Laptop Dverb test. The laptop is just for mixing/editing outside of the stu.
Dell Ispiron 1420 w/ Windows 7 Ultimate 32-bit T5750 2.0 Core 2 Duo 4GB Ram ST9500420AS OS drive Mbox 2 Micro No Aduio drive 62 PT8 Dverbs @ 24/48K 1024MB 90% CPU
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
#2388
Hi! Recently purchased the HP Probook 4520s and I got PT working on it I have not had the time to do a Dverb-test on it yet, but I can tell you that it worked better under W7 than XP.
I have the old Mbox and PT 8.0.1 and only disabled the networks in W7 so there was a ton of HP pre-installed crap running at the same time and I used an external USB-disc!!? I did get some error-messages after about a minute when recording 16 channels @256 but I think this was because I recorded to USB.. I will primarily use it to edit so I don't mind that for now, playback was fine of a session with 20+ tracks @ 256 buffer.. I had to bump it up to at least 512 sometimes 1024 in XP. This laptop doesn't have any fw but I will get a expresscard and try it out more to see if it improves anything in both W7 and XP. |
#2389
ok, did the dverb-test. recorded to an e-sata disc.
1024 buffer 24bit 48kHz 85%cpu, 93 dverbs. 1024 buffer 24bit 44.1kHz 85%cpu, 101 dverbs. |
#2390
I've been trolling the DUC for a while now to try and come to a determination on a good top of the line i7 laptop to purchase so I could run the current version of Pro Tools (8.03) with a 002 on a windows 7 64 bit system. I have my eye on a Sony VPCF114FX/H which is sold at Best Buy.
http://www.bestbuy.com/site/Sony+-+V...&skuId=9724544 I'm questioning the video card which is a NVIDIA GeForce 310M GPU From what I'm gathering a NVIDIA card is probably going to cause me problems from what I have read. Is anyone successfully running this laptop out there with PT? I cannot get my primary desktop, a Gateway LX series QuadCore running win 7 64 bit ultimate to run pro tools 8.03 and I have given up. I tried everything and have just come to the conclusion it is a wrong chipset and it won't work. |
USB support with Pro Tools 9 Laptops | moldenke | Pro Tools 9 | 4 | 11-18-2010 04:46 PM |
Dell Laptops and Pro Tools | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-03-2006 10:32 AM |
Best laptops for Pro tools | felixflank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-07-2006 06:41 AM |
alien laptops and pro tools | geefive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-29-2006 10:17 AM |
Pro Tools and Apple laptops | Jsalam112 | Pro Tools TDM Systems (Mac) | 1 | 04-08-2002 09:28 AM |
