Old 11-09-2011, 01:07 PM
DiscoBilly DiscoBilly is offline
Default Connecting 003 Rack to Presonus Digimax LT via Pro Tools LE 8.0.5. Help
I've been out of the loop for a few years now due to a broken back and am in the process of setting up some of my old and new equipment but I'm having a little trouble with my Digimax LT and can't for the life of me remember how to hook it up properly and was hoping someone here might be able to help.
I'm connecting my Digimax LT to my new Digi003 Rack using Pro Tools LE 8.0.5 on Mac OSX 10.6.8 (in the past I've done this with my 002).
I've got the ADAT cable going out of the Digimax LT and into the 003 Rack
In Pro Tools LE 8.0.5 in the Hardware menu I have Optical Format set to ADAT (not S/PDIF) and Clock Source set to Internal, if I set it to Optical I get a prompt that says the clock is invalid and that it's reverting back to Internal.
The Digimax LT LED's indicate it's getting a signal from my microphones, but when the Ext. Clock button is pressed the three sample rate lights just blink.
In the Pro Tools LE I/O Setup I have everything set to Default and all 8 of the ADAT channels show up and are selectable as inputs on all my tracks, but no signal makes it into Pro Tools LE.
Does anyone know what might be wrong here? Anyone else have a setup like this who would be willing to write out all their settings for me?
Thanks in advance!!!
Old 11-09-2011, 08:59 PM
Default Re: Connecting 003 Rack to Presonus Digimax LT via Pro Tools LE 8.0.5. Help
I think your trouble is spelled out right in the middle of your post. The session should be clocked to Optical. If that is not working(as you say) then right off the bat, there is a connection problem. A bad lightpipe connection will force the session to revert to internal, so start with the connection(make sure both ends are seated completely) or try a new lightpipe "cable". If you don't get the system clocked from the Digimax, all your lightpipe signals will click and pop(and they will be useless for recording). Also, make sure the Digimax sample rate matches the PT session, and only use 44.1K or 48K as the 003 will not accept higher sample rates on the ADAT input(but WILL on SPDIF, but that's 2 channels instead of 8).
Pro Tools 9 not cooperating with Presonus Firestudio and Digimax Fs MT21 macOS 3 02-17-2012 10:56 AM
Presonus Digimax connected to Digi Rack 002 help Jim Toscano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-23-2011 09:20 PM
Pro Tools LE And PreSonus DigiMAX help!!!!!!!!!!! DrummerGuy09 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-11-2005 09:50 AM
Pro Tools LE And PreSonus DigiMAX help!!!!!!!!!!! DrummerGuy09 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-10-2005 08:11 PM
DigiMAX by Presonus. MattStrat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-16-2000 02:58 PM
