Old 02-25-2016, 03:42 PM
Nathan W. Nathan W. is offline
Default Ivory II Sustain Pedal Problem...
I have no idea what's causing this but the sustain pedal seems to be releasing at random times. My actual keyboard audio sustains correctly...anybody provide me some insightful info as to what could be causing the sustain to be releasing too early?
Nathan
ProTools 11.3.2
Old 02-25-2016, 03:55 PM
Stig Eliassen's Avatar
Default Re: Ivory II Sustain Pedal Problem...
Is this during recording with MIDI Merge enabled? If so, it's very likely that you're experiencing the MIDI Merge bug.
Old 02-25-2016, 03:58 PM
http://protools.ideascale.com/a/dtd/...a-tab-comments
Old 02-25-2016, 04:21 PM
Thanks it was exactly that. I did find that the bug still occurs in LOOP RECORD mode, even with the midi merge "greyed out" / disabled. Weird right? You have to put the track into quickpunch mode and disable midi merge and it works correctly! Really weird bug. Did they fix this with 12?
Old 02-25-2016, 04:52 PM
This has not yet been fixed, no. I truly hate this bug. It's been around for ages.
Old 02-25-2016, 07:34 PM
Panacci Panacci is offline
Thats why I use Digital Performer when I need to record a midi piano session. As a pianist it drives me crazy . I thought they wanted to improve the midi experience with their product over the years. I guess no one listens or cares.
Mini Grand VI in PT11 sustain pedal problem OutbackStudios Pro Tools 11 3 01-03-2017 06:54 PM
Serious problem! piano sustain pedal controls tap tempo through midi! gvees Eleven Rack 1 07-28-2012 03:54 PM
Problem with sustain pedal still persists on PT 8.0.3 Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 51 05-12-2010 11:21 AM
Sustain pedal problem with Xpand and Ivory audiopostpicture Virtual Instruments 23 03-20-2010 04:10 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
