Old 02-13-2013, 05:59 PM
audiomark audiomark is offline
Default Machine Control w Sync I/O, Port = Bluetooth-PDA-Sync
I'm running Pro Tools HD 10.2.0 with the Machine Control option and when I navigate to the Peripherals setup I don't see either of the Sync I/O ports (1 or 2) for Machine Control. The only item visible in the Port selection pop-up is Bluetooth-PDA-Sync.
I have reset the firmware on the Sync but this doesn't seem like a Sync issue. PT sees the Sync fine - no problems manipulating it from the software. I just can't see the two ports.
I'm running a MacPro with an HD2, single 192 and Snow Leopard 10.6.8.
Anyone seen anything like this?
Thanks!
Mark
Old 02-13-2013, 06:30 PM
Chief Technician's Avatar
Question Re: Machine Control w Sync I/O, Port = Bluetooth-PDA-Sync
Is the SYNC connected to the port on your Core card or the first HDX card? Is the remote mode LED lit on the SYNC when Pro Tools is open?
Old 02-14-2013, 11:46 AM
Default Re: Machine Control w Sync I/O, Port = Bluetooth-PDA-Sync
Thanks for the note back...
Initially this was on a PT system with an HD2. It's now happening on a system with a Native card and Omni.
I swapped out the Sync I/O w another Sync Classic and host cable and the same problem is occurring.
I don't think it's a Sync issue - seems more like PT software not showing the 9-pin ports (for some reason). All other functionality of the Sync is normal. All three leds light on the sync, changing perameters works correctly for all functions in the Session Setup window.
I have another sync HD that is working correctly with Machine Control on a different MacPro - same exact OS & PT install. On that system Sync Port 1 and 2 show up - but so does Bluetooth-PDA-Sync.
Baffled...
Old 02-14-2013, 12:12 PM
quadraphonics quadraphonics is offline
With the Native systems and Pro Tools 10 you HAVE to use a USB to serial adapter (ie a Keyspan USA-28). It simply doesn't work properly with a native system.
Randall
Baffled...
Old 02-14-2013, 02:05 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Randall
Yup. Not well documented on the site at all.
http://avid.force.com/pkb/articles/e...rue&popup=true
I had to find out through the DUC (ta folks)
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 02-14-2013, 03:09 PM
Confirmed - the Keyspan works fine. Thank you sooo much!
The DUC comes through again.
Thanks!!
-Mark
HTML code is On
Machine Control COM Ports: Sync I/O vs CPU Tom Smith Post - Surround - Video 5 08-19-2008 02:10 PM
machine control and sync louisenslinproduce Pro Tools TDM Systems (Mac) 4 02-27-2007 10:51 PM
Sync I/O - Machine control problems Branko Post - Surround - Video 13 07-26-2003 04:38 AM
USD+Machine Control+Cannot Sync to LTC babyseal Pro Tools TDM Systems (Mac) 0 06-26-2003 02:11 PM
Sync & Machine Control blanos212 Pro Tools TDM Systems (Mac) 0 02-25-2002 03:03 PM
