Hi All,
I've never encountered this situation before, so I really appreciate any advice. I'm about to mix a documentary where the audio that was recorded to an external recorder was never used by the Avid editor while he was cutting - rather only camera audio. My question is: what is the best way to go about syncing it things from the external recorder? Which software/program/feature? It WAS recorded using the same timecode, but can I use that timecode info now that the cut is finished (lots of b-roll video placed over audio) - so do I need an audio EDL? Can avid do that? So stressful! ![]() Thanks in advance for any tips you can give me!!!!! ![]() |
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements Thank you, Craig |
Thanks Craig. Both other posts were downers, however.
Yes an Audio EDL will definitely help you. An avid will produce this.
Titan is the beast for this sort of task. It will only do as good a job as the EDL you provide it and settings you make. Be prepared to run a series of test conforms to establish the best settings to utilize. Always happy to help if you wanted to drop me an email. Ceri |
Thanks Ceri. Aware of any rental or 'cheap' or 'trial' version of the software. At about $2000 - it's really quite steep to 'try it out'. I may even be willing to pay, but if it doesn't work...
Anyone else have any good ideas? |
It has a 14 day trial. Straight from Synchro Arts.
![]() Quote:
frank.
PTHDn 2021.3 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
I will echo franks idea here, recently I had a 2 hour awards show that was edited using the line cut and instead of using titan etc. we loaded the multi track into the session and expanded to new tracks, this also helped since we could pick and choose which mic we needed, there were 6 live mics on stage and it would suck to have 6 channels of audio for every single announcer even though they were using only one of the mics. in PT 10 i believe you can now do this without loading all the multitrack audio into the session so you can keep things tidy, you can point it to a folder with all the audio.
Max Holland Producer / Re-Recording Mixer Nashville / NYC MKD Creative HOBO Audio |
How do I sync PT8 LE with my DV Camera? | luts | Post - Surround - Video | 3 | 06-27-2010 12:31 PM |
audio track sync(not MIDI) | rogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 12-04-2009 03:54 AM |
Super 16mm crystal sync camera on location w/ Pro Tools! | sorinnitoi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-29-2007 07:57 PM |
Digi 002 Rack - Sync to Camera? | totemspock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-09-2003 11:02 AM |
New audio track out of sync | Jeff Leites | Digidesign Hardware & Software | 1 | 11-27-2002 10:05 AM |
