Bounced .wav file doesn\'t work properly
Well gday all you Pro Tools pro's out there. Recently bought myself an MBox2 factory and I'm still learning the ropes. As it is, recording is a new thing for me. So far I've come up with a few problems, but I will mention the first one that has got me stumped. I have had a bit of a search through the DUC and the answer either hasn't been delt with or its just plain eluding me.
After I bounce to disk as a .wav file, when I go to open the file using Windows Media Player I get this error msg, "Windows Media Player cannot play the file. One or more codecs required to play the file could not be found" I downloaded the latst codec etc but that didnt work. I tired encoding the file to another type but none of the programs I normaly use will read it either. The closest I've gottn is bouncing it to an .aif file and it has worked with Quick Time but thats as far as my little adventure has gotten so far. Can anyone shed some light on my first Post? Daniel |
Re: Bounced .wav file doesn\'t work properly
when you bouce to .wav is it 16 bit joint stereo? If its any other sample rate Media player cannot cope.
Pro Tools Editor, Producer, Mixer and Masterer since 1998 |
Re: Bounced .wav file doesn\'t work properly *DELETED*
Post deleted by RadioMoo
Mbox 1 w/BLA mod, PTLE 6.1, eMac 700MHz, OS X (10.2.8), 1024 MB RAM |
Oh derr!!! Yeah that fixed my problem. So simple, so obvious. It didn't even occur to me that the sample rate was set to 24 bit. Thanks fellas and anyone else who would have helped me as well. Talk to use again soon.
Daniel |
Bounced file duration | Mack Truck | Pro Tools 10 | 6 | 07-24-2012 12:01 PM |
bounced tracks not dropping in properly | cali9dub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 09-17-2009 05:37 PM |
bounced mp3 file longer than source file | chobbs | Pro Tools TDM Systems (Mac) | 4 | 01-24-2006 03:00 PM |
Bounced file is distorted | pess80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-18-2004 08:21 PM |
Noise at end of bounced file....why??? | el biciclista | Pro Tools TDM Systems (Mac) | 4 | 07-02-2004 09:25 PM |
