Strike export to midi
Is it just me, or is strike's export to midi utterly useless? Unlike the manual, I have to create destination tracks. Fine.
But why in the hell do the notes not correspond to the same instruments in the individual hit section of the keyboard?. I copy a kick/snare/hat beat and when I play it back I get a sidestick/tom solo?!??!?!? Are you kidding me? Did I miss the part where exporting a pattern would then logically lead to midi tracks that would play back the same pattern in strike using individual hits? I'll even forgive the need to remerge the midi into one track, but why do I need to move notes, not to mention figure out where they should go. Please tell me this is a bug... |
Re: Strike export to midi
I have the same issue
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49 |
PUT THE SAME POST UP YESTERDAY. WAS TOLD THAT IT'S A A BUG THAT THEY ARE AWARE OF! MY ORIGINAL POST WAS TWO MONTHS AGO. STILL NO ANSWER FROM ANYONE ON THIS MESS. IF ANY NEWS LET ME KNOW. THANKS!
any luck??
Yep that sounds like my problem too. It just works funky and not in a good sort of way.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Me too. Strike would rule if only the feature I bought it for would work!
So let us be clear. Strike's Export Midi supposed to give you a full piano roll type midi track that you can edit note for note on a instrument or midi track?? Is there a way - I have used Groove Agent before - you can reroute the out put to a midi track? instead of importing individual pattern - if it works..
Also, is this "bug" in both PC and Mac Version?? ghj
Maybe I'm missing something...I only use the piano-roll midi track in protools to add and play preset patterns from Strike...and it works rather well.
003r/i7-930/LE 8.0.1 cs2 on xp |
I just got Strike 3 days ago. I was just bummed out that I could not use Strike's pattern in a traditional way - I know there are edit mode. Manual is terrible PDF only - I need also to find out if I need a odd beat measure - how can I do that.. so for every variation I have to create a separate pattern.. like old time drum machine. which a song was based on sequence of patterns. which is both good and bad.
I find it piano roll convenient that if your songs become complex.. I like to always put a one time only variation even within similar verse 1 and 2.. I have not really played enough to make and save my own pattern. But in any event they should fix the bug soon. ghj
Strike-Export Midi Problem...... | Bushpig | Virtual Instruments | 23 | 02-02-2011 05:26 AM |
You can export midi in strike | 77pro | Virtual Instruments | 45 | 09-06-2008 08:57 AM |
Strike Midi Export problem | John Prusinski | Virtual Instruments | 12 | 07-16-2007 08:22 PM |
Strike -Export Midi ->not working | brownj24 | Virtual Instruments | 3 | 01-29-2007 06:58 PM |
Strike - Export Midi Problem | Blank Frank | Virtual Instruments | 3 | 01-01-2007 03:33 AM |
