Old 10-03-2008, 02:00 AM
KimSira KimSira is offline
Default volume fader in custom fader mode
Hi all
When you select a channel in focus mode and that channel's plugin spreads across the custom faders, (all faders go to the bottum), is there a way to have one of the faders remain as the channel strip volume?
This is on a 24ch D-command.
Cheers
Kim
Old 10-03-2008, 04:10 AM
Stig Eliassen's Avatar
Default Re: volume fader in custom fader mode
I think you're locked to either 4, 8, 16 or 24 CF. I take it you're currently using all 24 in CF mode?
Old 10-03-2008, 07:06 AM
digimidi's Avatar
digimidi digimidi is offline
There is an console operations pref in the soft keys that is labeled PIDef (I think) that will let you decide what is on the faders when you are editing in custom plug in mode. Set it to Fader and your channel faders will still be available.
Gil
Gil Gowing
Principal
Digimidi Technical Services
Old 10-03-2008, 08:03 AM
Hi guys, thanks for replying.
I've got 8 faders set up for CF mode.
The PIDef option will keep the channel faders but it keeps all as they were.
What I am looking for is a way to have the focused channel's volume fader only. So you select a channel to bring to the CF focus, and you get that channel's volume fader on one of the CF faders.
Is this possible?
Kim
Old 10-15-2008, 09:54 PM
DHG MUSIC DHG MUSIC is offline
First let me apologize for the dumb response before, it had nothing to do with the topic
Second the real answer
I think if you setup your d command, so the focus chanell will open in the fisrt set of 8 faders of your fader expansion, you would be ok
go to console preferences and there you will find how to change it
Take care
hth
I used to be insecure...now I'm not really sure
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
Stuck in custom fader mode on D-Con? Inaam ICON & C|24 6 04-01-2010 12:30 PM
No Fader Flip In Custom Fader Mode? GlennR01 ICON & C|24 13 05-29-2007 04:40 PM
Custom Fader Mode on D-Command (TURN OFF) EvanScottSmith ICON & C|24 1 01-31-2007 04:07 PM
how do i get a volume fader in edit mode skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-18-2006 09:28 AM
