Old 09-08-2011, 08:44 AM
RLMartinez RLMartinez is offline
Default Recording Vocals with 11R
Has anyone had good results recording vocals through 11R? If so, please tell us how you are accomplishing that. I am using a Rode NT1-A (48v swith on) and have tried the "Mic Line In" input and the signal is so weak. Using the 11R input gives a hotter signal but it is processed through the 11R.
Any tips/suggestions would be greatly appreciated.
PT9.0.5
Win7-64bit
All latest drivers/updates applied
Old 09-08-2011, 09:15 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Recording Vocals with 11R
did you turn the gain knob up?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 09-08-2011, 09:32 AM
Yep. Just don't know what 'levels' I should be expecting. There may be another setting I'm missing.
Old 09-08-2011, 09:46 AM
DigiTechSupt's Avatar
Are you sure you have the 'pad' switch in the off position?
Avid Audio Tech Support
Support FAQ
Old 09-08-2011, 12:20 PM
Yes. 48v=on; PAD=off. I probably just need to continue to work with various combinations of settings/inputs etc... Also, I suspect the 11R Mic Pre is not intended to be replacement for more ProAudio level solutions so I may getting all of the output that the unit has. Don't know.
Old 09-08-2011, 12:34 PM
Benoni's Avatar
The 11R Mic input works just fine. There is no problem getting good levels. Maybe check the settings on your Mic, check your XLR cable as well.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 09-08-2011, 12:57 PM
Thanks Benoni and support. I'll continue to work it and report back here if I find a solution (discover the problem with my settings).
Old 09-12-2011, 10:06 AM
bascani bascani is offline
I once encountered the same problem but I ended up bangin my head against the wall. I was singing on the wrong side of the microphone. All I had to do was to turn the mic 180 ´.
Make sure that's not the problem :)
Old 09-12-2011, 04:33 PM
bassmanjazz bassmanjazz is offline
Hey, check out the site I've been working of for my band, flight case. Everything except the drums were recorded with 11, including all vocals. It's very possible.
Old 09-19-2011, 10:39 AM
Update... I worked with the 3 alternative inputs that I know about (Mic In, Mic/Guitar In, and Eleven Rack In). I was able to get fine results with the "Eleven Rack In" by using a clean amp (e.g. Q1 SL-100 Clean) and just a little reverb.
Recording Hip Hop Vocals Matty503 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-20-2010 11:10 PM
recording vocals with 002 bigboi78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-28-2007 12:38 PM
RECORDING VOCALS! dec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-16-2006 05:42 AM
Recording vocals 101 craig s Tips & Tricks 1 09-18-2004 07:16 AM
Recording Vocals Willie Baker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-08-2002 02:07 PM
