Turn mono to stereo?
I am dragging and dropping audio files from NI Maschine into Protools. However, everything is in stereo, which uses up 2 tracks for each sound. So when I drag and dropped my kick drum pattern into PT, my kick drum is now in a stereo pair. Is there a way to turn this stereo pair into a mono signal? I don't want to just delete one of the tracks because I'm afraid I might losing some important frequencies or harmonics. Thanks for any answers.
Re: Turn mono to stereo?
Also, if I were to keep a sound such as a snare as a stereo pair, how can I pan it 20 percent left? Would I slide both tracks 20 to the left? Is that the same as sliding 20 to the left on a mono signal?
Stereo tracks have 2 pan "knobs" so you can match them and pan anywhere you like(just as with a mono track). another option is to pan the stereo track in a narrow spread(like 10 and 2 o'clock), or shift it off to either side(like 1 and 5). As for wasting tracks, you can split a stereo track to dual mono, then highlight the original stereo and one of the 2 mono tracks and "hide and make inactive". In any case, a mono sound like kick or snare, on a stereo track is likely to not lose harmonics, just ambience(if there is any). That can be recreated with subtle use of reverb(with a short room patch). Most of my drums are from SD2 and, instead of the room mic sounds built in, I usually leave them out and feed my own "room"(a particular verb plugin) that creates my own sound.
How about importing it as a region then dragging the region onto a mono track?
When I export the sounds from Maschine as wav files into a folder and then drag a sound into PT... it is still in stereo. So every sound NEEDS 2 tracks. Is there no way to merge 2 audio tracks into 1?
If you HAVE to have a mono track then just bus your stereo track to a mono audio track and print it. Walla
If you have a soundfield category AS-plugin process sum-to mono then delete the unwanted stereo. SUM (-3) would be a nice export or import feature.
What about the original stereo field coming from NI do you want to keep? Some modulation or verb? I'm wondering from your post if you're really just getting the same exact sound on both sides, and you're just afraid it will be "less" if you only use one side. Just use one of them as mono, and turn it up!
I'd rather create a mix starting from a dry sound anyway. If you import drum sounds with verbs or FX on the source tracks, then you don't have any flexibility down the road to change them when you realize they're getting in the way of any other sounds. If you absolutely can't export the sound as mono from NI, then import the file as stereo, then in ProTools use the "split into mono" command and listen to both sides to see if one of the mono sides won't fulfill what you need from that sound. If not, either leave it as stereo and eat the extra voice allocation, or take a moment to bus them to the same mono track.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
How to turn a stereo track into mono | remusjacobs | Pro Tools 10 | 10 | 08-15-2012 09:47 PM |
making mono track into stereo or double mono in PT7LE | VeganMuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-02-2012 05:36 AM |
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-14-2010 09:01 AM |
Turn Mono Room to Stereo? | ronstephens | Tips & Tricks | 3 | 03-09-2008 04:38 PM |
How can I turn a stereo track into a mono track??? | LitheVite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-18-2007 02:51 AM |
