Old 06-27-2019, 10:43 AM
lampmusic lampmusic is offline
Default New macbook pro 2018 13' roll back os to Sierra?
There is info all over the web on how to do this with High Sierra. I would love to restore my current system (sierra).
Every thing was working well for me on sierra for both PT and Adobe CS 4.
I've tried every step I could find to do this including making a bootable installation disk to no avail.
The 2018 MBP will only re install mojave.
Any advice or guidance would be appreciated.
I'm sure there are others in the same boat.
Main System MBP 2016 (touch strip) 16G Ram.
I own a PTHD 11 which I still use on a native system in main studio (not sure if is worth the $ for reinstatement)
Doing most of my mixing work in PT 12 vanilla.
OS X 10.12.6
Old 06-27-2019, 04:18 PM
Default Re: New macbook pro 2018 13' roll back os to Sierra?
has no one done this?
OS X 10.12.6
Old 06-28-2019, 12:55 AM
what do you mean *new* MacBook Pro. What are you changing?
How about explaining in simple English what you are doing and why? You are trying to clone or reinstall stuff that was running on another Mac before or on this exact Mac?
Look up your exact model Mac on easymac or some other resource and check what the minimum supported OS version is.
If an earlier OS version is supposed to run then provide a link to exactly what instructions you are following.
What exactly happens? What exact error etc do you get?
Old 06-28-2019, 03:18 AM
JFreak JFreak is online now
Sierra was released 2016 and don't have all the drivers needed for your 2018 laptop, simple as that, cannot be done.
Old 06-28-2019, 08:36 AM
What i have tried to do several times is to restore the complete Sierra system from a Time Machine backup. The error says "this backup was created with a different model mac"
the backup was created with a 2016 MBP 13 inch.
Going a different direction, I attempted to install Sierra on the 2018 MBP 13 inch from a usb drive install. If this was successful, I would then restore from the Time Machine backup I had created from the working 2016 MBP that I had created on Sierra.
This didn't seem possible since it would revert to internet recovery every time and re-install mojave.
The only other idea I had was to reach way back in my experience level and create a Carbon Copy Cloner bootable copy if the working Sierra system and then copy it onto the new 2018 MBP via target disk status.
I sincerely appreciate any brainstorming help on this option.
The main reason for staying on sierra is that I also use Adobe CS4 - I am poor and can't afford Adobe CC subscription. (photoshop seems to be working ok in 10.14, but Indesign appears to be a no go)
OS X 10.12.6
Old 06-28-2019, 11:12 AM
I suspect you cannot do this. As I said go check the minimum supported OS spec for your model Mac. I suspect JFreak is right. But you should go check. Forced OS upgrades are a big part of planning and new Mac purchase.
If it’s not documented as supported it is not going to run, nothing anybody can do here to help you. You need to either return/sell the Mac and buy an older one or upgrade macOS and Pro Tools. 2019.6 on Mojave is a really nice release.
Old 06-28-2019, 11:34 AM
xrekcor's Avatar
xrekcor xrekcor is offline
......or upgrade macOS and Pro Tools. 2019.6 on Mojave is a really nice release.
+1 rock solid here a lot of bug fixes in the last 2 updates too
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
Pro Tools 2019.6-23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 06-28-2019, 05:24 PM
Sincerely thanks for the replies. I haven't gotten rid of the 2016 13 inch. I also have a working 15 inch (2017 / I7 ) running sierra.
Just brainstorming to see if it was possible on the new MBP that come with mojave pre installed.
OS X 10.12.6
Old 06-29-2019, 01:08 AM
No, it isn't.
Because Apple does not backport drivers of new hardware to old operating systems, you cannot use older operating systems on newer hardware. Drivers are not downloadable from apple.com but instead come with the operating system (naturally starting with the version they originally shipped from the factory).
Either you need to forget Sierra (easy to upgrade to Mojave really, and 2019.5/2019.6 work really nice with it) -- or you need to be such a knowledgeable guy that can copy drivers needed from the current operating system install. I suspect you aren't that guy because you're asking seriously, nobody in their right mind shouldn't even try.
Command 8 work with high sierra and 2018.xx? analog orange ProControl, Control|24, Command|8 6 05-12-2019 05:41 PM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
PT HD 2018.1 HDX and High Sierra on Mac Pro Westmere 3,33 drums77 Pro Tools HDX & HD Native Systems (Mac) 5 02-24-2018 12:16 PM
High Sierra 10.13.3 PT 2018.1? off the wall macOS 10 02-16-2018 08:25 AM
