Old 08-15-2012, 05:37 AM
remusjacobs remusjacobs is offline
Default How to turn a stereo track into mono
How do i turn a whole track of stereo audio into a mono?
I have some high hats i recorded from a Motif and it recorded it hard right. Im trying to mono the audio track to pan it less.
thanks
Old 08-15-2012, 07:23 AM
Iron Shirt Iron Shirt is offline
Default Re: How to turn a stereo track into mono
You should be able to route a stereo track to a mono bus and then create a mono track that receives input from that bus. I know there are plugins (I think Blue Cat makes one) that can sum as well.
Old 08-15-2012, 07:33 AM
Dot Dot is offline
Just simply split the track into mono and delete what you don't need. If you panned it hard right there's no need to even sum left channel since nothing is there. make your life easy
www.dominicdotokune.com
Old 08-15-2012, 07:43 AM
Or adjust the 2 pan knobs on the stereo track to the same position and closer to the middle. BTW, if you Alt-click on a pan knob, it will jump to 12 o'clock(that trick will default or "zero" most any setting in PT and in plugins).
Old 08-15-2012, 08:40 AM
browniespeaks browniespeaks is offline
Default
The Downmixer plug included with pt will do the job if you want the audio summed and then attenuated. Just in case there's a little more in the left channel than nothing
Sent from my SGH-T769 using Tapatalk 2
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 08-15-2012, 09:47 AM
capt kirk capt kirk is offline
does the PT native include the downmixer plugijn? i can't find it anywhere...
www.kfaudio.ca
Old 08-15-2012, 12:15 PM
phatbeatstudio phatbeatstudio is offline
Isn't there away to split a stereo into two mono tracks with out bussing.
Or is it make two mono into stereo. I have thought about that myself the work around is easy enough but I thought there was a keyboard short cut for it .
Old 08-15-2012, 12:56 PM
adflaker adflaker is offline
You can also insert the stereo width plugin and dial the width to 0%
Old 08-15-2012, 01:06 PM
Stig Eliassen's Avatar
Indeed.
Old 08-15-2012, 09:29 PM
Default
@capt I believe it is under the sound field sub menu
Clifford Brown III
www.brownaudio.com
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
Turn mono to stereo? typhy macOS 7 10-06-2011 11:14 AM
Turn Mono Room to Stereo? ronstephens Tips & Tricks 3 03-09-2008 04:38 PM
How can I turn a stereo track into a mono track??? LitheVite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-18-2007 02:51 AM
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 06-26-2002 03:21 PM
