Old 11-20-2008, 03:13 PM
Elton Hyland Elton Hyland is offline
Default May be a stupid question but...
If I load a MP3 file into PT, is there a way to increase or decrease the volumn of the file witout having to bounce the file again? Seems like a lot of work just to alter the volumn on a MP3.
WinXP Pro. 003 Rack, Command 8. Alesis Powered Monitors, Roland XP80 Kbd. Dual core 1.8 w/ 2 Gigs RAM
Old 11-20-2008, 03:22 PM
Greg M Greg M is offline
Default Re: May be a stupid question but...
Elton,
Yes there is. Use an Audiosuite plug-in to increase the gain or compress it then select it in the regions list (on the right of the Edit screen) and choose "Export Regions as Files" to your location and format of choice.
Greg
Old 11-20-2008, 03:27 PM
OK I can use my compressor on the audio track. I tried this earlier but wasn't sure if it worked or if I needed to put the compressor on another track. I'll give it a go. Thx
Old 11-20-2008, 03:32 PM
RussUK RussUK is offline
Normalize may help in the Audiosuite
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 11-20-2008, 03:33 PM
I tried to use the COMPRESSOR / LIMITER Dyn3 that came with PT but it doesn't seem to have an effect. any ideas?
Old 11-20-2008, 03:38 PM
spkguitar's Avatar
You might want to try the Trim plugin...
Old 11-20-2008, 03:42 PM
Hmmmm Don't see the trim plugin. Would that be on the main menu under the audiosuite?
Old 11-20-2008, 03:46 PM
spkguitar's Avatar
Trim is RTAS.
For Audiosuite processing, use the Gain plugin (as Greg mentioned in the first reply ).
Old 11-20-2008, 03:48 PM
I tried the compressor plugin under audio suite instead of accessing it on the INSERTS bar on the track. I then previewed it and it works that way. I wonder why it wont work accessing the plugi vua the mix window?
Old 11-20-2008, 03:50 PM
OK gang. I got it. Thanks a bunch. It works using the gain function but I was just trying to access it in the wrong spot. Cheers!
Stupid stupid question but I need to know chicken macOS 2 05-28-2011 08:48 AM
General Midi Question and another stupid question... imcivor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-04-2007 02:39 PM
Very Stupid question!! adlib311 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-31-2007 10:45 AM
very stupid a/d question sipi1910 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-01-2002 12:37 AM
This probably is a stupid question, but badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-25-2002 09:11 PM
