recorded midi is ahead by 1/32 note!
Couple of issues here.
1 A session originally recorded in 7.4 on Tiger when opened in PT8 had this problem: The drum track was being triggered live from Reason 4 (latest version) and arriving in PT via an Instrument channel. The track was playing about one 32 note ahead of the rest of the track. When I looked at the midi notes they were perfectly on the beat. Now sometimes I have to delay certain VI about 10 or so milliseconds because they trigger faster than others but this was so out of whack that I had to manually shift it. But before I did I replaced Reason with Addictive Drums. Same thing happening!! So the midi looks correct but is triggering ahead of the beat. I messed with Delay compensation. Went from short to long. No difference. Turned it off, no difference. 2 And this is even stranger. Today on a track started in PT8 I was recording a midi part with Omnisphere. I played the part in and thought I was in the pocket. On playback the part was 1/32 note in front of where I played it. So in one song the midi looks correct but plays in front and in the other I play correctly but the midi is recorded ahead of the beat and appears that way. (input quantize is turned off) So that's some new behavior. Anyone seen this before? Am I missing something obvious here? (I'll admit I'm a bad dancer but I'm usually "behind" the beat. Never forward!!!)) |
Re: recorded midi is ahead by 1/32 note!
Check Midi real-time properties for the track and Midi offsets in the Events menu.
I have found that opening sessions from others brings in their settings and I have had them stay after moving to or creating another session. If you don't find anything here, trash all the midi prefs with the Pro Tools prefs and database helper. |
As I suspected it was a simple thing. I had changed my buffer to 1024 and that's where the problem is.
It's always the change of routine that gets you. |
has anyone else noticed that the beat clock read out in quarter notes does not fire in time with what is heard?
and no..there is now limiter on the 2 bus
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Audio Recorded from MIDI track ahead of the beat/grid | CalebB | macOS | 1 | 10-22-2012 11:03 PM |
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
MIDI note not recorded at the time I play | drums77 | MIDI | 1 | 09-12-2010 07:12 PM |
First mdi note not being recorded | tripstation | Pro Tools TDM Systems (Win) | 2 | 09-15-2008 03:02 PM |
Recorded MIDI is ahead in playback | BiggiT | MIDI | 7 | 06-06-2007 11:17 AM |
