Old 03-06-2011, 04:48 PM
J2sound J2sound is offline
Default "mapped output inactive"??
I used VENUE Link to setup my firewire recording and 2 channels won't "record enable" because they say "mapped output inactive". I can't figure out how to fix.
Justin
Old 03-07-2011, 02:31 PM
doug sjostrom doug sjostrom is offline
Default Re: "mapped output inactive"??
If you can see the I/O in the Edit window, right click the output and select "Make Active". You can also do this in the Mix Window.
Doug Sjostrom
Old 02-27-2012, 08:20 PM
tempesax tempesax is offline
I tried to do this.
I right clicked on the Output Path Selector and selected "Make Active."
I got an error message saying, "The output could not be made active because its mapped output is currently inactive."
What the heck is a "mapped output" and how do I make it active?
Old 02-28-2012, 12:09 PM
Try going to Pro Tools I/O Setups page and look at the Outputs tab. Are any outputs UNchecked or overlapping? If they are, try defaulting in I/O Setups or you can choose another output for the track.
Doug Sjostrom
Old 08-19-2012, 03:03 AM
ollydrums ollydrums is offline
I am Running PT 9.06 with a 003 on OSX. This has also happened to me where I cannot use outputs 3-4 on the 003. Everytime I try to route tracks to these or any output other than 1-2 the pathway greys out with "mapped out innactive"
any help with this would be great. Thanks
Old 08-20-2012, 02:33 AM
don't-be-a-dingbat don't-be-a-dingbat is offline
In PT9 and PT10 there are now output busses (I/O Setup, Bus tab, see page 99 in PT9 ref guide and page 100 in PT10 ref guide for more info on signal routing in these versions). It would also be worth checking these are set correctly.
As long as the output bus is mapped and it is active in this tab, there should be no issues.
The input path "S/PDIF L-R" was made inactive because its stem is missing. ampnerd macOS 3 02-05-2014 08:58 PM
Freeze when "Some paths were made inactive..." message appears (10.3.6) SlicerSounds Windows 1 07-07-2013 10:20 PM
PC freezes when "Some paths made inactive....." message appears (10.3.6) SlicerSounds Pro Tools 10 0 07-04-2013 11:11 PM
Channel I/O keeps loading old I/O and not "no input"/"no output" Arve Gotfredsen macOS 4 02-12-2013 04:38 AM
Mapped Output Inactive.. Weird error message sylviesongs macOS 0 11-02-2011 02:29 PM
