#21
Re: Error installing required components...PT 11
What I am about to ask you to do could make your situation go from bad to worse. By proceeding, you understand that I am not liable or responsible if something goes wrong.
You just changed the permissions on the directory containing the plug-ins (and the plug-ins themselves via the -R option) to Read & Write for all users. The -v option means verbose, and you should see a list of which files were subjected to the command you entered. Remember - If something bad happens to your system, I am neither responsible or liable. Please respond with how well this does (not) work to solve your problem.
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) Last edited by Chief Technician; 06-23-2013 at 09:12 AM. Reason: Left out a directory in Terminal steps. |
#22
Chief - before I get started I want to assure you no liability! I really appreciate your help. Be back in a few.
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
#23
Odd. Says "no such file or directory." Sent from my PT beating heart
#24
I tried it and this is what was in the window:
Last login: Sun Jun 23 11:49:10 on ttys000 cty:~ CTY$ cd /Library/Application\ Support/Avid cty:Avid CTY$ sudo chmod -v -R 777 Plug-Ins sudo: can't open /private/etc/sudoers: Permission denied sudo: no valid sudoers sources found, quitting cty:Avid CTY$ |
#25
I have all access for writing and reading for everyone (System, Admin and Everyone)
#26
I did what you just said with Terminal and it comes back with this "No such file or directory"
Attempted to start PT11 again and got the same "error installing..."
"Are you sure what side of the glass you are on?" www.facebook.com/thereapersofficial |
#27
After restart I get the same start issue. I will continue to monitor - I may just re-install OSX from scratch!!
#28
Gonk, you and I had the same screen shot. Somewhat encouraging.
#29
Its not gonna help... |
#30
Tx. I will be patient.
Error installing 7.4 ! | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-16-2007 12:58 PM |
Email Required Error? Help with the website! | samuelowen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-19-2005 09:53 AM |
Initialization Error - Updated driver required | Larry Younkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-13-2005 10:25 AM |
Installing 5.1.1 error | deanmartinez | Pro Tools TDM Systems (Mac) | 0 | 01-17-2005 03:41 AM |
error: "A Digisystem INIT is required." | gloriavin | Digidesign Hardware & Software | 1 | 10-10-2003 02:27 PM |
