#41
Re: Eucon 20.5 Automation Lag
I installed the earlier build, no change. Still lags. Would it help if I sent a session (no media) or anything else I can do to help track this down? Thanks
IMDB |
#42
how can i get rid of it? what do you mean "network related"? how to fix the network? how to make it work? |
#43
interestingly, the auto lag is gone when i came back to v 20.5.0.149
just got this loong "everyting lag" after switching apps, and the 2-4 seconds display lag now |
#44
generally current version of eucon is extremely unstable. ranom lags occure and disappear. display lags, avid control panner lags, automation lags. you never know what will happen next.
exactly the same setup used to work with no problems 2 years ago |
#45
This is my experience exactly. When I got this system (right after the spill function was added) the switching between spill/layouts etc was instantaneous. The newer Eucon releases have made the system incrementally more laggy over the last couple years and the last 2-3 versions have hobbled it entirely.
#46
Can anyone seeing the automation lag turn off this setting and see if goes away. Dock Automation Mode Buttons Follow Att Track
#47
YES! Running Eucon 20.5.0.149 and turning off "Dock Automation Mode Buttons Follow Attentioned Channel" fixes the lag problem. Hopefully that points the programmers in the right direction on how to fix it permanently! Thanks Eddie!!
Carlos Sanches Re-Recording Mixer Audio Circus Warner Bros. Animation http://www.imdb.com/name/nm0760851/ |
#48
hopefully this leads to a fix. Thanks Eddie!
IMDB |
#50
Thanks - 20.6 works as efficiently as before (maybe even better) Thanks!
2018.7 Automation choppy with Eucon controller | SFXgeek | Artist Series | 11 | 03-18-2021 09:06 AM |
Logic 10.4.2 breaks Eucon automation modes. | robertg | Artist Series | 25 | 05-19-2019 04:59 PM |
Eucon/Artist Mix Trim Automation selection | HotRats_Reloded | Artist Series | 1 | 10-06-2018 05:29 AM |
automation mode glitch almost fixed in Eucon 3.4 ??? | yoerik | Avid S1, S3, Dock and Control App | 7 | 09-05-2016 07:15 AM |
PTHD 12.1 and EuCon automation | reichman | Artist Series | 1 | 07-09-2015 10:45 AM |
