Mixing Down for Radio
I have heard that radio stations require a special mix down for songs to sound good over radio. Apparently it has something to do with the songs being compressed before being played over radio.
Does anyone know anything more about this? How do I mix down for radio if I don't know how it is going to sound? Is there anything in PTFree that makes this easy? Cheers, Michael [img]images/icons/smile.gif[/img] |
Re: Mixing Down for Radio
Aim for a bright, punchy sound without any bottom below 60 Hz or top above 15KHz, as those aren't broadcast anyhow, and will cause the Optimod multi-band compressors to clamp-down on all of the rest of your audio.
Just keep the frequency spectrum even in your mix and you'll probably sound good in broadcast. I can't remember what plugs come w/PTF; use the equalizers and a limiter on your master track before you bounce to disk... Try to not compress everything too much, because the radio station will squeeze it like an orange under a steamroller anyway. [img]images/icons/cool.gif[/img] Keeping a log of the mastering settings you used and tracking/evaluating the on-air results will lead you to tweaking the sound that works best. Every engineer sets their broadcast chain a little differently so it's about impossible to be more specific! |
Some EQing as written to keep it in the freq. can be aired.
Compressing usually to "Squash" compression (A LOT of compression)
Just wanna do music, RA. |
Try it both ways! But I tend to agree more with Arno Peeters:
De-essing is a good thing, too. A little goes a long way in that area, as well... co2 adds: Quote:
Pro Tools For Radio Production, Adobe Audition And Google Radio Automation... | The Weed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-09-2008 07:51 PM |
FM Radio Mix Help | DezMented | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-12-2005 10:37 PM |
Mixing for Radio | AverageJoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 10-28-2002 10:03 PM |
Best radio automation program for professional radio stations? | GuitarEasley | General Discussion | 22 | 03-23-2002 11:32 AM |
Radio EQ ? ! | nobby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-08-2001 04:13 PM |
