  #51
Old 10-06-1999, 05:42 PM
Garry Garry is offline
Default Re: HUI Electromagnetic Field (Part 2) The sequel
Fellow HUI Users,
I too had the aforementioned sticky fader problem, and solved it in the following manner: I ran a length of Monster Cable from one of the screws on the bottom of the HUI (the ones on the perimiter, screwed into the chassis) to a copper water pipe in a corner of my control room. Problem solved. Hope this helps.
Garry Rindfuss
  #52
Old 10-09-1999, 09:48 AM
imported_yes imported_yes is offline
To tell you the truth, I think Mackie has dropped the ball on HUI. Their R&D is concentrating on making their own DAW. The last time I talked to Mackie, they don't even get current updates from Digi to test the HUI with!. The HUI has the potential to be a very exandable unit (Fader packs/ethernet) but it still basically the same unit since it's release. They did however change the faders due to the problems with the original ones. I did have problems with faders also. But after the third one, I got one that I've been happy with. Also the tech at Mackie said that if anyone has a continual fader problem they would take the unit back and refund your money.
yes
DUC Move sequel - StudioTimi meets Al Schmitt Screener Pro Tools TDM Systems (Mac) 14 09-17-2010 01:36 PM
Near Field Monitors muzak13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 06-20-2006 08:22 AM
Near-field vs. far-field monitoring Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2002 06:37 PM
Amp for Near Field ProductionEngelads 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-26-2002 02:54 PM
Q650/601/66 upgrade card and PT..THE SEQUEL nymo Pro Tools TDM Systems (Mac) 1 03-27-2000 07:50 PM
