Old 07-26-2002, 08:48 PM
KamaSutra77 KamaSutra77 is offline
Default Mixing buss latency?
Hi , I am curious as to whether or not there is latency introduced by the mix buss in PTLE. What I mean is, if I set up a effects buss, then route the sends of various channels to that bus address, does the audio out of the bus have letency compared to the send output?
I guess I could set it all up and find out, but curious what others users have expereinced. I am getting closer to mastering (sic) some material as a quality check.
Huh?
Old 07-27-2002, 03:18 AM
Shameless Shameless is offline
Default Re: Mixing buss latency?
Try command clicking the volume indicator in the i/o section of your channelstrip.
You will see a reading for delay induced by plug-ins on the bus track. I dont think that pertains to routing latency though.
I seriously doubt you will have any trouble unless maybe you are useing a send and return set up with external processing units.
Or using the hardware i/o feature in one of you 5 available inserts.
Would i get any latency w/external comp for buss Detuned6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 04-25-2006 12:38 PM
Buss latency, how bad? derF Pro Tools TDM Systems (Mac) 1 03-29-2004 06:23 AM
A question about mixing with latency... AppleFunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-22-2004 09:53 AM
Digitally mixing around the latency thing banana boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-26-2002 12:01 AM
TDM Buss latency.When will it be fixed? J Fernandez Pro Tools TDM Systems (Mac) 28 05-19-2001 04:17 AM
