Old 06-28-2021, 08:14 PM
Noel58 Noel58 is offline
Default only enables 1 track to record
brand new here - first time using protools or any DAW - have follwed youtube tutorials BUT will only allow me to enable 1 track recording ...if I click to enable the other one (scarlet solo) the first one turns off ???? feel ignorant but still gona try...thanks for any pointers in advance (didn't find in search of FAQ)
Old 06-29-2021, 01:26 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: only enables 1 track to record
Have you gone to the i/o setup page and tried createing2 inputs. one for the mic pre and another one for the instrument input? this should then give you 2 separate inputs available on 2 separate tracks.
But i'm not sure if the SOLO allows both to be used at the same time. if it does its going to be one microphone track and one instrument/guitar DI track
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-29-2021, 03:37 AM
its2loud its2loud is offline
Auto-cancel previously record-enabled tracks
When you’re in a creative flow, you need to move quickly. But sometimes, you might forget to disable record on a take you want to keep and record over it. Now, a new preference makes sure that never happens again. It allows you to select how Pro Tools behaves when you record-arm an audio, MIDI, or instrument track. So that when you press record, all previously record enabled tracks are automatically disarmed. And you will avoid recording accidents of this nature from here on out.
https://www.avid.com/avid/data/Video...1-E8BD7C5B2C54
Old 06-29-2021, 07:55 AM
That^^^ and another solution: Click the first track's record button, then Shift+click the next track's record button
Old 07-01-2021, 04:07 AM
The link isn't working right and returns a page saying there's an error.
Jack
QAPLA!
Old 07-01-2021, 05:36 AM
Well that’s a bummer. It was working a couple weeks ago when I posted it for someone else having the same issue.
Selecting a track record enables it e_man macOS 24 10-14-2015 11:01 AM
Alt/Opt+Drag plug-in to a new track enables all Automation Parameters Frank Kruse macOS 10 03-11-2013 02:09 AM
Error message when i try to record. "track could not be record-enables...." znera143 macOS 3 01-20-2012 06:17 PM
Error message when i try to record. "track could not be record-enables...." znera143 macOS 2 01-02-2012 07:41 PM
record enables on groups of stereo pairs c-post Tips & Tricks 6 06-18-2001 10:39 AM
