How to use Korg Legacy Triton oinside PT 2021.3.1
I have bought Blue Cat Patchwork program in order to use VST Korg LegacyTriton synth but it doesn't work. Does someone know how to use Triton inside this version of the PT.
Thanks! Dagg Last edited by Dagg; 06-03-2021 at 08:10 AM. |
Re: How to use Korg Legacy Triton oinside PT 2021.3.1
Hi, Isn't Korg legacy 32bit? thought it was dropped long ago. Chris
Did you mean Blue Cat? Assuming you did, you would insert Patchwork in the top slot of a stereo instrument track. Inside Patchwork, you would insert the Triton VST. Put the track into record-ready and playing your midi keyboard should play the sounds. Its possible that it may not work as not all VST plugins are happy working in a wrapper(but I have no direct experience with the Korg stuff. I do find it odd that the Triton is the only plugin in the entire Korg suite that isn't compatible with Pro Tools(maybe that will change in the near future)
Chris was writing at the same time and he may be correct. Beyond that, do other instrument plugins work?(just wondering if its only Triton or if you have no instruments working)
Actually it shows TRITON word inside PatchWork app as if it was loaded and when I enable record it plays first patch via keyboard. But I cannot change patches and cannot see Triton plugin main screen, it doesn't popup like other VST plugins do. JUNO-60 as a VST3 plugin worked.
Re. 64 bit I installed 64bit AAX version of PatchWork because PT is installed as a 64bit Windows app. I hope this is ok. Thanks for any help, I was so excited to record Triton inside the PT project and I bought Triton and Patchwork (USD 350 value) for that purpose but cannot do it. Last edited by Dagg; 06-03-2021 at 09:43 AM. |
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X |
I am afraid Triton doesn't work as AAX yet. That's why I had to buy PatchWork.
P.S I have been officially informed that using Triton inside PT 2021 via Patchwork doesn't work Last edited by Dagg; 06-04-2021 at 12:45 AM. |
Korg Triton and PT 7.1 | foxlemieux | Tips & Tricks | 8 | 10-24-2007 09:54 PM |
What is the difference between Korg Triton Classic and Triton LE??? | Big Tyme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-23-2002 04:50 AM |
What is the difference between Korg Triton Classic and Triton LE??? | Big Tyme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-22-2002 06:00 PM |
Korg Triton & Mac G3 | Dr. J | Pro Tools TDM Systems (Mac) | 1 | 03-18-2001 09:08 AM |
Korg Triton... | deadfold | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-16-2001 10:41 AM |
