Song bounce length
I searched but couldn't find an answer. When I did an offline bounce, the file is 1 min longer past the last note in the session. I checked for any hidden edits, volume, pan, but can't see anything that would cause it to do that. I did notice that my timeline window can scroll all the way to measure 500, even though the song 'ends' at 80 something. I also tried highlighting the measures beyond the last note and hitting delete, but they remain. What am I overlooking?
Music is the Message |
Re: Song bounce length
Did you HIGHLIGHT exactly what you want to bounce first?
It does the same thing to me, Just make a timeline selection from where you want the end back to the start and it will only bounce that length.
Yes, that's how it works. Don't highlight anything, it bounces the entire length of the edit window.
Thanks for your replies. I don't remember having to highlight the song unless I wanted it to extend beyond the last note played ex reverb tail. I must've been doing it without realizing it before, because my bounces would end after the last sound.
Part two: How do I make the timeline shorter? 500 extra measures just can't be right. Would it have something to do with the 'Default Length' preference?
Highlight EXACTLY what you want to bounce, no more, no less. It's always worked that way. Don't worry about the timeline.
I must've been sending a lot of 'dead' space without realizing it once I started using offline bounce. So used to thinking it stops automatically. Wonder where I got that idea? DP, or Logic perhaps
Thanks for setting me straight! I know now to be more careful with the bounces and just highlight, highlight, highlight. There, that should be enough so I won't forget to do it!!
Selecting the longest recorded track from start to finish is the way, in Edit Window.
unless you have a video or Midi. |
How to edit song length | ozzymau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-15-2004 07:01 PM |
how to reduce the length of a song! | MrMike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-23-2003 09:00 PM |
song length | loserfriendly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-12-2001 07:27 PM |
Change the length of a song. | davedog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-15-2000 12:19 AM |
Song Length? | doc22 | Tips & Tricks | 2 | 12-03-1999 07:02 AM |
