  #141
Old 08-22-2010, 01:32 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Pro Tools placing sound EARLY??
I just did the test Leaving PT 8.0.4 installed, uninstalling the Avid Audio 64x driver and INSTALLING the 8.0.4b driver. This seems to fix everything. Insted of placing the audio early, it is now slighly late, which is normal latency.
This test was done on the 003R. The 11R is un-affected by either driver, places audio correctly.
Here is the proof
http://drop.io/BenoniStudio/asset/8-0-4b-jpg
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #142
Old 08-22-2010, 01:36 PM
mykhal c's Avatar
mykhal c mykhal c is offline
This test was done on the 003R. The 11R is un-affected by either driver.
Here is the proof
my findings also with the 002. analog input with my bass was accurate in placin' the audio in the timeline. looks like 8.0.4b drivers will be what one will need if they wanna run on W7 x64.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #143
Old 08-22-2010, 01:59 PM
TOM@METRO's Avatar
Mine is still shaky with 8.0.4 and 8.0.4b driver although improved.
But 8.0.3 cs2 with the 8.0.4b driver is spot on nailed.
I'll go back and look at 8.0.4 with the beta driver and see if I can get it in line.
I have separate drives for all these combinations.
This was all done with a 002r.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #144
Old 08-22-2010, 02:02 PM
mykhal c's Avatar
But 8.0.3 with the the 8.0.4b driver is spot on nailed.
does your 8.0.3/8.0.4b setup mirror Benoni's pics?
  #145
Old 08-22-2010, 02:29 PM
TOM@METRO's Avatar
No. The waveform on the return to the record track is more what you would expect to see from a headphone output into a mic. I am using an AKG 240 into a U87. Timing is similar though.
I have had varying results now with restarts and re- installations of the beta driver with 8.0.4. I evidently need to nail down some variables.
8.0.3/4b cs2 remains stable.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #146
Old 08-22-2010, 02:35 PM
mykhal c's Avatar
I have had varying results now with restarts and re- installations of the beta driver with 8.0.4. I need evidently need to nail down some variables.
8.0.3/4b remains stable.
so does that mean it lines up identical to the bussed click on the audio1 track?
  #147
Old 08-22-2010, 02:36 PM
TOM@METRO's Avatar
Virtually identical with 8.0.3/4b cs2. Not with 8.0.4/4b. (002r)
EDIT: I am using the stock converters for this test. Buffer 64
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #148
Old 08-22-2010, 02:42 PM
mykhal c's Avatar
so just so i'm clear...8.0.3/4b cs2 mirror Benoni's pic? about 150 samples later?
  #149
Old 08-22-2010, 02:53 PM
TOM@METRO's Avatar
Let me start again. 8.0.3/4b cs2 is spot on (not late) the headphones are on the mic. All is well.
Now after many re-installs of the beta driver over 8.0.4 the click is constantly coming back late about 147 samples. On my first test with this setup there were different results but after re-installing the beta driver and a couple restarts, this has become consistent (147 samples late). I prefer the results of 8.0.3/4b to the results of 8.0.4/4b. 147 samples is too much latency for me.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #150
Old 08-22-2010, 03:01 PM
mykhal c's Avatar
got cha....thanks for spellin' it out
Pro tools placing Samples Early. the opposite of latency. thecoaster macOS 11 06-30-2013 02:54 PM
pro tools is recording early? Applebase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2010 07:44 PM
Early Film Sound Pioneer, George Groves minister Post - Surround - Video 4 05-22-2009 01:08 AM
Early Beatles Sound AmazingOne Pro Tools TDM Systems (Mac) 47 02-10-2008 02:49 AM
film print sound 2 frames early minister Post - Surround - Video 8 04-13-2005 09:37 AM
