Old 07-25-2007, 07:50 PM
lamp lamp is offline
Default 003 default i/o and S/PDIF mirroring
On my 001 I could select spdif mirroring in the setup dialog. I used it all the time to send the stereo mix out to a DAC-1. Its not there in the 003 PT7 setup. The work around Ive been using is to go to the i/o setup and create a new spdif path on the output page and select it as my Master track output. What am I missing here????
Old 07-26-2007, 02:35 AM
peppertree peppertree is offline
Default Re: 003 default i/o and S/PDIF mirroring
It's what's Digi missing. They haven't implemented it yet. Bad digi.
`My name is Pro Tools HD, King of Kings:
Look on my works, ye mighty, and despair!'
Nothing beside remains. Round the decay
Of that colossal wreck, boundless and bare,
The lone and native DAWs stretch far away.
Old 07-26-2007, 11:59 AM
I hope it was only an oversight. I have many sessions with group bus outputs that have to be changed one at a time. Ive discovered that you do not have to option click SPDIF & 1&2. SPDIF will work by itself if you create an output path for it in the i/o setup.
Mirroring outs 1-2 to S/PDIF Jperkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-24-2009 08:15 AM
S/PDIF Mirroring Support on 002 jawknee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 02-18-2006 01:18 PM
S/PDIF mirroring analog I/O on 002 Sadie Tango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-08-2003 09:07 AM
Anyone with 6.1- did they fix the S/PDIF mirroring bug? Stone Knife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-08-2003 05:22 PM
S/PDIF Mirroring bstaley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-11-2000 06:58 AM
