-9129 -9093 -9094 problems
32 voices/ tracks 11 plugins.
3 ren comp's - 2 ren eq's 4 bands - 1 waves flanger - 1 waves super tap - 1 waves doubler 2 massey - tape head - L2007 - 1 ozone. Computer at 20% Why does this Keep happening? I have removed pci usb's reformatted hard, started over. Defraged hard drives to digi recommendation. All plugs are up to date. Whats next???????? 7.1 cs 10 SiSoftware Sandra System Host Name : STUDIO User : Rich's Studio Workgroup : MSHOME Processor Model : AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ Speed : 2.00GHz Model Number : 3800 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI IMB USB i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : American Megatrends Inc. 0219 System : System manufacturer System Product Name Mainboard : ASUSTeK Computer Inc. A8V Total Memory : 2GB DDR-SDRAM Chipset 1 Model : ASUSTeK Computer Inc K8T880Pro CPU to PCI Bridge Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1000MHz (2000MHz data rate) Total Memory : 2GB DDR-SDRAM Memory Bus Speed : 2x 166MHz (332MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : RADEON X1600 Series Adapter : RADEON X1600 Series Secondary Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : WDC WD400BB-22JHC0 (37GB) Hard Disk : WDC WD600BB-00CAA1 (56GB) Hard Disk : WDC WD800JB-00JJC0 (75GB) Hard Disk : LEXAR JD EXPRESSION USB Device CD-ROM/DVD : SONY DVD RW DRU-820A (CD 40X Rd, 8X Wr) (DVD 5X Rd, 1X Wr) Logical Storage Devices XP (C:) : 75GB (56GB, 75% Free Space) (NTFS) BFD (D:) : 56GB (38GB, 68% Free Space) (NTFS) Audio (E:) : 37GB (11GB, 29% Free Space) (NTFS) CD-ROM/DVD (F:) : N/A 3.5" 1.44MB (A:) : N/A Removable Drive (G:) : 489MB (476MB, 97% Free Space) (FAT) Peripherals USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : Generic USB Hub USB Controller/Hub : USB Mass Storage Device USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Composite Device Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Microsoft PS/2 Mouse Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Network Drivers Enabled : No Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: -9129 -9093 -9094 problems
bump
Digi Support.......help the boy out!! Obviously there's a problem here.
bump.......
DIGI WOULD YOU PLEASE HELP!!!!!!!!!!!!!!! I WOULD LIKE TO RECORD OR MIX A SONG WITH OUT GETTING BUFFERING PROBLEMS
For technical support from Digidesign, it would be best to contact customer support directly. This DUC is a user information sharing community and although a Digidesign administrator chimes in occasionally, you may not get much in terms of a response from Digi here. In looking over your Sis Sandra report, everything look okay to me. The buffer errors are often associated to the hard drive not keeping up with the demands of Protools so you might check to see if there is anything that might be causing disk access delays. You are recording and playing back from a physically separate drive so that is good but perhaps there are bad sectors or extensive fragmentation of the data. Make sure you are not using any from of RAID or disk mirroring. Also make sure you are not using antivirus utilities. This is a tough one as everything looks like it should be fine.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I have no antiviruse on the computer it is stripped. Recording only. I am using ide drives. Would this be a problem? I see my disk usuge at 30%. The operating system does not share the same cords. I need help with this. Im to the point that Im getting sick of recording. Customer support is no good for me now. I dont have Raid never set one up and ASUS said that disk mirroring is not part of there program.
Microsoft info or you can google "stuck in PIO"
Yes they are in DMA mode. Ive checked several times to make sure. Transfer mode is - Ultra DMA mode 5.
Help! Errors 9092, 9093, 9094, 9129 persisting! | doobaGeoff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-27-2007 06:32 PM |
Dual Core Processor Affinity / 9093 9094 9129 | ikelk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-21-2006 01:31 PM |
MBOX,WINDOWS XP and 9092,9093,9094 problems | genebadd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 01-25-2003 06:59 PM |
Interrupt errors -9092/ -9093/ -9094/ -9129 | saxbill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-18-2002 11:41 AM |
problems with digi001 errors 9129/9094 | basschair | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-31-2001 07:30 AM |
