Simple for you upgrade?
I have a brand new PC and Digi 002 with 2 installation CDs. One is Pro Tools 6.1.1 and the other is 6.9 which I just learned that it's the update. Do I need to 1st install 6.1.1 and then upgrade to 6.9? I also down loaded 7.0 but I don't know if I have to follow from oldest to 7.0. Please help.
Thank you |
Re: Simple for you upgrade?
If you have the 7.0 installation (and the code necessary to make it work), all you need to do is run that. You do not need to load the older ones, and it's probably better if you don't.
Thanks but do I turn on my Digi 1st or just install the download 7.0 upgrade and turn it on after?
I believe the unit has to be on during the install.
Digi recommends to turn it on before you turn on your system. I've found this isn't a problem during installation, but it's a habit you should get into in general. Power strips->AD/DA->Digi->DAW.
It's simple: don't upgrade. | huzzam | Pro Tools 10 | 143 | 10-30-2011 08:23 PM |
Simple question re MPTK upgrade | b mcgibney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-17-2009 12:20 AM |
ProTools 7 LE Upgrade...Please Help Simple Question | indefilm23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-26-2007 04:04 PM |
Simple question regarding upgrade | batboy | Pro Tools TDM Systems (Mac) | 2 | 01-23-2007 03:41 PM |
Upgrade help: Guitar instr. pre (Avalon, etc) vs. simple DI | cleft | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-27-2003 10:23 AM |
