Old 03-15-2006, 03:09 PM
neofat neofat is offline
Default Mbox BIG Problem
I have a huge problem with my Mbox(1), when i'm using my Protools LE 6.9 cs4 (running on a G5 Biproc 1,8 Ghz, with Panther X.3.9, core audio 6.9), some times the sound drop out, and i hear a sound like a white noise, its very noisy and when it hapens, I go to the hardware setup change the source from analogue to spdif and again to analogue, and it stop the noise. Then i can work till the same noise restart.
I think there's a probleme with the internal clock, any idea?
Thanks, and sorry for my english.
Old 03-16-2006, 10:07 AM
Slim Shady Slim Shady is offline
Default Re: Mbox BIG Problem
This is something that has come up before, but I don't remember a specific fix for it.
Looking at your setup - did you let Quicktime 7 get installed along with 10.3.9? Quicktime 7 on 10.3 is a well known cause for lots of problems with PT, although I don't know that the white noise thing is one of them. You might first want to experiment with using a powered USB hub for your Mbox, that sometime clears up strange behaviour, and it's not to hard to downgrade to Quicktime 6.x should you decide to give that a shot - there's instructions on Apple's support pages on how to do the downgrade.
You should also just check out the "General Troubleshooting" thread, maybe something in there will solve the problem.
Old 03-18-2006, 11:16 PM
Rivritt Rivritt is offline
This sounds like the same thing I was encountering. I would get this after doing long form editing with FCP and/or Soundtrackpro. After finishing either, if I went to any app using the coreaudio... FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF. My solution is to toss the coreaudio pref. Yeah it still happens here and there. But at least I know now how to fix it, instead of pulling out my hair wondering what the problem is...
Old 03-19-2006, 06:59 PM
Moz Moz is offline
Try to update with "MBox Firmware Updater Rev 20" (http://www.digidesign.com/download/mbox/) even if the updater "said" you already have the later version. I've fix the same problem with this metod after see it sugested by a Digidesign moderator in DUC.
Mbox 2 Pro crashed Pro tools 11.1.2 - Solved problem bought new Mbox 3 ;) shamanrock Pro Tools 11 0 02-15-2014 03:36 PM
MBOX PROBLEM PLEASE HELP! shanepjones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-09-2007 04:00 PM
Mbox to Mbox 2 Pro upgrade problem Zumwalt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-08-2007 12:58 PM
Help: Problem with MBOX 2 Bouni 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-21-2006 06:16 PM
mBox problem- help! Billy Claire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-18-2002 01:47 PM
