Pro Master 20 bit interface
What Pro Tools system does this interface work with? Does anyone know? Does it work with newer systems? Thanks!
Re: Pro Master 20 bit interface
The ProMaster 20 Interface was used with a Sound Accelerator II/2 or a 442 Audio Card (both are NuBus). The main app that supported this was Sound Designer II.
Here are its specs: Sample rates: 44.1k & 48k (user selectable). A/D convertor: Ultra Analog ADC 20048; 128x oversampling; true 20-bit output. A/D Frequency Response: 5Hz to 20kHz +/- 0.1dB. A/D THD+noise: -104dB (@-60dB 20 to 20kHz). A/D Phase response: 1 degree @ 10kHz; 10 degrees @ 20kHz D/A Converter: Burr Brown PCM63; 8x oversampling; 20-bit input D/A Signal to noise: >104dB(20Hz to 20kHz). D/A Phase: +/- 3 degrees @20kHz. Digital I/O bit resolution: 16 or 20-bit in, 16 or 24-bit out (switchable in SDII HW Setup). † Digital I/O: AES/EBU Type I (pro) or Type II formats; XLR connectors. Analog inputs: +4dBu; female XLR x 2; active balanced; pin 2 hot. Maximum input level: +24dBu. Slave Clock I/O: 256x FS, BNC jack (x2). Slave Clock lock range: (varispeed) > 40kHz < 51.4kHz. Metering: Digital monitoring, Sample accurate, 12-segment LED meters, displays output only. Power: 100 120 220 240 VAC manual switching 50/60hz 60 watts maximum. Dimensions: 2U rack mount 19" W x 3.5" H x 15" D. Weight: 16lbs.
• linkedin •
Master Control Interface for Lynx16(w/ADAT)??? to replace Digi002 | milesholmwood | macOS | 3 | 09-11-2012 11:58 PM |
Master and Slave Interface HELP ME! | [email protected] | Pro Tools 9 | 1 | 09-28-2011 08:04 AM |
TC Master X3 new interface confusion? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 6 | 09-01-2011 05:45 AM |
Fixing Clipping in Master in Master Fader | pakobo7 | Pro Tools M-Powered (Win) | 10 | 09-16-2006 10:53 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
