Old 03-15-2024, 08:47 AM
daeron80 daeron80 is offline
Default Bug: Select/Split notes
It's impossible to set a note range below C0 in the Select/Split Notes dialogue. I use this when transferring orchestral MIDI to a score editor to remove the key switches (all below B-flat -1) from all tracks at once. Granted, it's possible to select all tracks, open them in the MIDI editor window, and manually select the key switch range. But if I have a lot of tracks (which is usual) it takes forever for the MIDI editor to display it all.
PT 2024.3, both Mac and Windows machines
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 03-15-2024, 01:07 PM
MDGenerato's Avatar
MDGenerato MDGenerato is offline
Default Re: Bug: Select/Split notes
Hi, David here from the Avid Community. I'll try reproducing this one. Thanks!
Old 03-15-2024, 01:32 PM
skylar_battles skylar_battles is offline
Confirmed. Same issue here.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Select/Split notes not working in PTLE7 Mcgrathx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-23-2013 06:32 PM
Split midi notes? Workflow? JonLance Pro Tools 9 9 08-07-2011 09:41 PM
MIDI Select/Split Notes - Assertion in PT8 gonzolagonda Pro Tools TDM Systems (Mac) 3 08-18-2009 05:34 AM
7.4 Crash on Select/Split Notes paulmellors 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2008 08:40 AM
Midi - Split Notes in Pro Tools bassbuddy MIDI 2 09-18-2006 04:46 PM
