Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 03-11-2024, 05:46 AM
tetonica's Avatar
tetonica tetonica is offline
Default Carbon Pre Settings Keep Resetting ?!
Is there a way to preserve the I/O settings on Carbon Pre? My main Carbon interface is fine but my Carbon Pre (x2) interfaces keep resetting every time Pro Tools boots up.
When the 2023.12 Pro Tools version came out my Carbon Pre (x2) started resetting their settings (all inputs change from line to mic). I was hoping that with 2024.3 the issue will go away but is still happening... not sure if there's a firmware upgrade available (don't see the option in Carbon Central)
Any help or tips would be greatly appreciated
Old 03-11-2024, 05:50 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Carbon Pre Settings Keep Resetting ?!
Hi you can try a firmware reset.
https://avidtech.my.salesforce-sites...roubleshooting
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 03-11-2024, 10:07 AM
tetonica's Avatar
Originally Posted by jeam25 View Post
Thanks -- I've just tried the firmware reset but no luck. Both Carbon Pre (x2) have all their inputs reset from line to mic inputs.
Successfully did the firmware reset to both Carbon Pre (x2) and to the main Carbon interface and then upgraded the firmware to all units.
But even with the Pro Tools Setup-->Hardware settings selected option to "Retain Mic Pre Settings" still all settings get reset from Line to Mic when loading Pro Tools
Old 03-18-2024, 03:00 PM
MCorbin's Avatar
MCorbin MCorbin is offline
Hey Tetonica
We've reproduced this in house. I'll see if someone in Support can reach out to you and set up a case so we can get this to Engineering to fix.
Nice catch!
mark
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 03-18-2024, 04:31 PM
tetonica's Avatar
Originally Posted by MCorbin View Post
Hey Tetonica
Nice catch!
mark
Excellent - thank you!! I'll be around if support reaches out
Hope it's an easy fix
Old 03-18-2024, 09:34 PM
tope d's Avatar
tope d tope d is offline
Hi!
I've started a support case under 04774372. Team will reach out via Email.
Thanks!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-19-2024, 05:30 AM
tetonica's Avatar
You guys are amazing - thank you !
Old 03-27-2024, 02:07 AM
tetonica's Avatar
Yesterday I was contacted by Avid Pro Tools Technical Support, and as part of the troubleshooting, I was required to rollback to Pro Tools 2023.9.
  • Rolled back from Pro Tools 2024.3 to 2023.9, and when loading Pro Tools 2023.9 the Carbon Pre (x2) settings are not reset
  • Re-installed Pro Tools 2024.3 and when loading Pro Tools the Carbon Pre (x2) settings are reset
Will keep you guys posted when I hear back from the support team!
Old 04-13-2024, 07:36 AM
pweinrobe pweinrobe is offline
I am having this same issue! very annoying!
Pro Tools | Carbon & Carbon Pre compatibility with AVID S4 Control Surface [email protected] Pro Tools | Carbon 9 09-14-2023 10:36 AM
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? pm mastering studio Pro Tools | Carbon 0 12-22-2022 01:54 AM
Resetting I/O settings TDM -> LE Colorblind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-20-2007 07:11 AM
'resetting' Plugin settings ? Arno Peeters Pro Tools TDM Systems (Mac) 1 09-05-2000 09:12 PM
