Old 11-25-2014, 12:49 AM
jacko's Avatar
jacko jacko is offline
Default 5 most missing features from S3
If you had to name 5 most missing features from S3 control surface, what would they be?
Here is my list:
- user maps for plugins (like on Command|8)
- automatic focus on plugins that are targeted on screen (like on Command|8)
- Soft Keys on top row of encoders, where color LEDs and scribble strips could get some use for snapshots, memory locations, etc.
- VCA layer (like on Command|8): user layouts are great, but it would be awesome if we had a layer with VCA groups only without having to set it up manually. Also, VCA Spill layouts independent from show/hide in Pro Tools would be useful as well
- quick creating custom fader layouts from channels that are selected in Pro Tools. Currently setting them up one by one in Eucon window is a bit slow.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 11-25-2014, 12:25 PM
Tom Graham's Avatar
Tom Graham Tom Graham is offline
Default Re: 5 most missing features from S3
Here is my list:
On the upcoming December 9th webinar we have some tips on how to setup Layouts with Pro Tools quicker… Stay tuned for links to register after the holiday.
I will pass along your feedback.
Thanks,
Tom
Tom Graham
Avid Audio Marketing
Pro Audio and Mixing
[email protected]
Check out our Pro Mixing Webinars :
http://www.avid.com/US/resources/pro-mixing-webinars
Avid Pro Mixing Blog:
http://www.avidblogs.com/promixing/
Old 11-25-2014, 01:43 PM
studiosus studiosus is offline
1. custom plugin mapping (you can already do that with the artist series working with nuendo, come on..)
2. vca spill for the control surface mode
3. properly displayed automation mode on the display. latch for latch, touch for touch, read for read and so on like on the s6. not just r for read and rw for latch and touch, like on the artist series.
4. preference to switch the track record arm button to the automation mode select button by default.
5. as much user defined buttons as possilble (at least the whole automation window should be accessible without having to press the shift button
these are absolute musts for me. without that, i'm not going to buy it. although i'm waiting for more than two years now for a better solution than the artist series..
Old 12-19-2014, 03:31 PM
jacko's Avatar
Thanks,
Tom
I watched the webinar and it seems the only way to create custom layout is selecting tracks one by one. That's not what I originally meant.
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Old 01-24-2015, 01:25 AM
Promixengineer Promixengineer is offline
Yes, in use, I find that my most important feature would be mapping custom layouts from the surface with out ever having to look at eucon. Should be as simple as selecting a number of tracks and then pressing and holding one of the layout buttons for 3 seconds or something. that or hitting multi assign and then the layout button of choice. Definitely a must. The layouts are the real strength of this controller, but setting them up is the most time consuming part of the mix prep. I have created mix templates to get around this, but there's no one size fits all template…
Second to this would be properly displayed automation modes….
[SOLVED] PT10HD License but HD features are missing Oblivion777 Pro Tools 10 3 08-27-2012 06:43 AM
M-Audio Drivers missing Older Features Dog BBQ Pro Tools M-Powered (Win) 5 06-07-2010 08:27 PM
Strike Missing Features - Brushes, shuffles... dazlm Virtual Instruments 1 09-16-2007 07:13 PM
Missing automation features in LE Headmxr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2007 11:33 AM
Missing Features in 5.1u Przemek Pro Tools TDM Systems (Mac) 3 11-21-2001 12:05 AM
