  #81
Old 12-08-2013, 09:21 AM
Drywsef Drywsef is offline
Default Re: Screen Freeze - Plug-ins periodically become 'corrupted'
Originally Posted by dave911 View Post
A while back in the thread you said you had no crashes with all plugins removed from the plugin folder.
If it is a NI plugin then you should be able to remove just the NI plugins from the plugin folder.
Could still be something related to NI like increased disk activity from loading samples, etc.
Thanks, Dave. I plan on doing that... I had noticed that the crashes would happen even if my NI VIs were inactive in a session - it seems that even having transient master or solid mix series active was enough to crash my system. I'm not true what it is... I never had this problem with NI AAX64 plugins. Maybe something's up with their AAX32 coding?
Win 11 22H2 - PTU 2023.9 - HDX - Blue 192 - Prism Titan
i9 10900K, Asus Tuf Gaming Z490 Plus, Corsair Vengeance LPX 32GB, NVIDIA 1070ti
OS/apps, sessions, and samples all on separate drives.
  #82
Old 02-22-2014, 01:26 PM
jonathan jetter jonathan jetter is offline
hi there- i realize this is a couple months after the fact. but i'm going through something very similar. and i have similarly tried many, many things to troubleshoot.
i also thought that my problem was due to Komplete Ultimate 9, and probably Battery specifically. then i also saw problems in sessions w/o Battery, but w/ Guitar Rig or Kontakt.
i think i may have hit on something just now- someone on a Gearslutz thread recommended to remove all the NI Solid Mix plugins. i've moved them all to the "unused" folder (and also the DBX 160, 1176, and LA2A and EQ plugs just to be sure).
since doing that, i have not yet been able to reproduce the crashes, and (knock on wood!) all seems stable.
maybe worth trying on your end? best of luck!
Pro Tools 11 Screen Freeze? wdjudd Pro Tools 11 13 01-06-2016 11:46 AM
Structure update corrupted the display screen Rusty Tatem Virtual Instruments 1 10-13-2007 12:27 PM
Echo boy screen freeze Greene Pro Tools TDM Systems (Mac) 1 07-28-2006 09:50 AM
Screen Freeze Sulaco Digidesign Hardware & Software 1 07-24-2002 05:54 PM
Is a corrupted Plug-In causing freeze &/or killing song? ArtWood Pro Tools TDM Systems (Mac) 3 05-07-2002 06:33 AM
