Old 11-07-2013, 05:18 PM
dave911's Avatar
dave911 dave911 is offline
Default Re: Screen Freeze - Plug-ins periodically become 'corrupted'
The DPC looks good.
Outside of reinstalling PT you could run a disk check and defragmentation on your drives.
Don't run the defrag. with PT running!
Scheduled defrag should be turned off for a PT system.
Also, running "sfc/scannow" at a admin. DOS prompt will check for bad system files
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra
Old 11-07-2013, 05:25 PM
Drywsef Drywsef is offline
Default Screen Freeze - Plug-ins periodically become 'corrupted'
Thanks, Dave911. I'll give it a shot and report back tomorrow. Another update for now: I tried performing a full uninstall and reinstallation of 10.3.7 and the same problem persists today.
Win 11 22H2 - PTU 2023.9 - HDX - Blue 192 - Prism Titan
i9 10900K, Asus Tuf Gaming Z490 Plus, Corsair Vengeance LPX 32GB, NVIDIA 1070ti
OS/apps, sessions, and samples all on separate drives.
Old 11-07-2013, 08:18 PM
I tried defragmenting the drives and running that command. I have attached the result. The problem still persists; however, the last few times PT froze/crashed, the DYN III plug-in was inactive. I can no longer attribute this to the DYN III plug in. With no plug-ins activated, the issue will not occur. However, if I only activate my 3 VIs, (Battery, Absynth, and Kontakt), the freeze will come on. I really ask for it when I try to save. That usually brings the freeze/crash on. Memory related, perhaps??
About ready to pull out my hair.
Old 11-07-2013, 08:50 PM
Check your task manager when your running and see where your system ram is during the session. For best results to check this, temporarily turn off disk cache to check. If your hitting around 3.5gb of memory usage, your in trouble territory.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 11-07-2013, 09:13 PM
Thanks for this. Am I looking to see how much RAM the entire system is using, or just Pro Tools?
  #16
Old 11-07-2013, 09:14 PM
Pro Tools.
  #17
Old 11-07-2013, 09:16 PM
This will give the system total, but the app total is also viewable in here. With only PT running, it would be maxing out around here somewhere. I am guessing this could be the issue. To bad you did not have PT 11 to verify.
pro-tools-pc.com
Intel I7 9900k
Win 10
  #18
Old 11-07-2013, 09:35 PM
I do have PT11 to verify. What exactly am I verifying? To see if PT11 uses more RAM with the same session?
  #19
Old 11-07-2013, 09:39 PM
You would be confirming that Pro Tools 11 does not suffer from the problem you are seeing. The suspicion here is you are hitting a 32 bit related limit in Pro Tools 10, Pro Tools 11 being 64 bit does not have that limitation.
Darryl
  #20
Old 11-08-2013, 06:35 AM
dave911's Avatar
Also, have you reinstalled the MOTU drivers?
Besides running out of memory in PT as others suggested you may have a memory leak. So you want to watch the memory usage from boot up and see if it is high before you start PT.
Pro Tools 11 Screen Freeze? wdjudd Pro Tools 11 13 01-06-2016 11:46 AM
Structure update corrupted the display screen Rusty Tatem Virtual Instruments 1 10-13-2007 12:27 PM
Echo boy screen freeze Greene Pro Tools TDM Systems (Mac) 1 07-28-2006 09:50 AM
Screen Freeze Sulaco Digidesign Hardware & Software 1 07-24-2002 05:54 PM
Is a corrupted Plug-In causing freeze &/or killing song? ArtWood Pro Tools TDM Systems (Mac) 3 05-07-2002 06:33 AM
