Avid Mbox 3 and Focusrite ISA One Digital
Hey all,
I recently purchased and installed the optional digital card for my ISA One Preamp. I'm trying to use the s/pdif connection into an Avid Mbox 3 into Pro Tools. The problem I'm having is that I can't seem to get the ISA to work in anything but 44.1kHz. Which it seems to work fine in. I read through an article on the focusrite answerbase and I noticed that it said that you had to select the sample rate on the ISA and then change the mbox's clocking to s/pdif. However, when I turn on my ISA and press the 'clock select' button on the ADC panel- nothing happens. None of the sample rates light up or anything. I'm wondering, is there something wrong with my unit? Have I installed something incorrectly? Wondering if anyone else has had this problem... Like I said, it seems to work fine in 44.1kHz. My concern is that the first ISA One Analogue I bought had a glitch where the cue mix button didn't work. Thanks for your help! |
*Fixed*
*Fixed*
Not sure what the issue was, but taking the card out and re-installing it seems to have done the trick. I must've had a loose connection somewhere. Working great now! Guess you have to be smarter than the pre-amp... |
Avid mBox Pro - Digital Clock | DoubleG | Pro Tools 9 | 7 | 04-25-2012 01:24 PM |
ProjectMix Digital I/O with the Focusrite ISA 428? | Robbie Hollywood | Pro Tools M-Powered (Win) | 7 | 10-31-2007 03:25 PM |
PT 6.1 and FocusRite IAS 428 Digital Output | edemunari | Pro Tools TDM Systems (Mac) | 3 | 09-10-2003 05:58 AM |
Focusrite 428 w/digital option | Jopry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-25-2003 08:45 AM |
Focusrite ISA 220/digital card/001 | mhvoiceuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-21-2002 01:59 AM |
