Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 04-01-2011, 06:33 PM
Default Re: Intel Builds for Pro Tools HD Native
New build added to first page plus Nvida Graphic Card notes from zion here.
Aaron Mulqueen - 001 HD Native
Old 04-09-2011, 06:54 PM
GA-X58A-UD3R Rev.2 BIOS FF now available. BIOS Fg1 beta released.
Old 04-10-2011, 03:57 AM
mlange's Avatar
mlange mlange is offline
filosofem - perhaps a stupid question.....
can you use PCI Express cards in the PCI Express 2.0 x16 slots on your GA-X58A-UD3R?
Thanks,
Mark
________________________
www.PlethoraTone.com
PlethoraTone Studio Video Tour
At PlethoraTone:
Mac Mini M1, Avid Carbon,
PSP, Waves Mercury, UAD, Kush, Slate Digital,
PA, Melodyne, Antares, Audioease, SoundToys
Old 04-10-2011, 05:26 PM
Hi Mark
You are referring to the PCIe Native card, yes you can. I have mine seated in the second PCIe x16 slot. First PCIe x16 slot hosts the graphics card. The Native card is PCIe x4.
Old 05-05-2011, 08:07 PM
Sugarnutz Sugarnutz is offline
Here's a rig I spec'd for some of the guys over at Gearslutz and one I plan on building for myself at some point:
Gearslutz DAW
Cheap at around $1100. I'm torn between a HD Native/HD16-16 analog/Omni setup or a SSL MX4/Alphalink/PT9 rig. It should work well with either.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
  #16
Old 05-05-2011, 08:40 PM
Intel H67 over P67 Chipset?
  #17
Old 05-07-2011, 10:52 AM
The last thing I want to do to a DAW is try and overclock which is the advantage to going P67. The H67 has a graphics capability (built in to the cpu already and receiving good reviews against all but the higher end video cards) which looks suitable enough for DAW work, even having a display port with 2560x1600 resolution for those pesky 30" monitors. With 16 gig of RAM I don't mind sharing 512 meg with on-board graphics. Stability is what I'm looking for at a fair price point, these new Sandy Bridge rigs deliver that. The particular motherboard I listed also has 3 PCI slots for HD cards or UAD1 cards if needed which is a plus over other solutions.
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
  #18
Old 05-07-2011, 12:36 PM
GA-X58A-UD3R Rev.2 BIOS FG 2011.05.02 released.
  #19
Old 05-07-2011, 12:56 PM
Pro Tools does not support integrated graphics chipsets.
  #20
Old 05-07-2011, 07:22 PM
Why? There's lot of things that PT has not officially supported over the years like AMD processors as an example, didn't stop people from using them and with great success. There's no switch in PT to automatically disable itself when an on-board video card is present. Another thing is that there is a big, fat 16x PCIe slot on the motherboard I mentioned which you can stick a $40 video card in if needed.
The big pluses of the motherboard I mentioned is the support of a reasonably priced 3.4 Ghz i7 CPU, 16x PCIe slot, 4x PCIe slot (required for a HD Native card), two 1x PCIe slots for UAD 2 cards or RME/Lynx/SSL interface cards and 3 PCI slots you could possibly use for HD Core/Accel cards if you wish.
The main argument I had for the H67 chipset was not needing to overclock the CPU. I have tried many times over the years to run an overclocked system for DAW use going back to that infamous ABIT dual Celeron board with the proper unlocked Celerons intended for it. Too many possible errors with ram and IDE controllers back then. Just decided overclocking was not worth the effort when you can get a solid, stable system without it.
Sometimes it's just better to keep things as simple as you can. The system I listed achieves that.
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
I7 Builds with Pro Tools 10 Caatalyst Windows 31 03-28-2014 10:32 AM
Would HD Native work with Intel Ivy Bridge on PC? Rockman413 Pro Tools HDX & HD Native Systems (Mac) 12 07-03-2012 01:43 PM
How long before PT9 goes fully X64 Native and builds in VST support ? ben ifin Pro Tools 9 13 11-22-2010 08:14 AM
Waves Native bundle and intel macs Illl0lll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-22-2006 08:56 AM
Universal Bin? Native Intel Version? Clue??? goldfinger Pro Tools M-Powered (Mac) 0 05-17-2006 08:14 AM
