Old 08-26-2008, 11:28 PM
Trifektor Trifektor is offline
Unhappy 002 Rack Connection Issue
Hi all,
My name is Niko and am brand spankin' new on this forum.
I just picked up a used PowerMac G5 dual 2.3GHz w/ 4.5GB RAM and am having a heck of a time connecting my 002 R. Basically, when I connect the interface to the front or rear firewire ports of the computer, the indicator LED on the front of the 002 doesn't light. I've gone through the following:
* Used new firewire cables from the 002 to the computer
* Re-installed PT twice
* Reset the PRAM on the computer
* Verified firewire bus is functional (connected firewire drive to port one at a time and each time, the drive was able to launch - even w/ firewire 800)
* Connected 002 to my MacBook Pro laptop (w/ Intel chip) and verified PT is able to launch
* Checked the firewire status in the system profiler and (with the drive connected directly to the second firewire port on the 002) the drive was showing up but the 002 is presumably an 'unknown device'
* Connected 002 without external drive connected to it (connected drive via USB)
* Checked all over Digi's site that I meet the minimum hardware and OS requirements
* I've cleaned all the firewire contacts with compressed air
* I've updated OS X with automatic updates as well as offline combo updates
* I've tried out a ton of combinations of cables
I've determined that the audio hardware itself is good on all accounts but it's just not communicating with the comptuer which appears to be good as well.
I did use the 002 on XP before but I'm fairly confident that this has nothing to with the functionality of the hardware since it doesn't appear that the hardware itself has firmware versions to update - it's the software which has the updates.
Any ideas? I'm going a little nuts.
Cheers,
Niko
Old 08-27-2008, 01:57 AM
The Dougfather The Dougfather is offline
Default Re: 002 Rack Connection Issue
Hi Niko, sounds like the dreaded power harness failure. It's very well documented, do a search. Also Digi are happy to help on this issue, you just need to contact them.
A good way to see if your a potential sufferer is to look at your serial, if it has anything other than a G, i.e. A-F, then it's a high probability. The issue wasn't fully addressed until Revision G.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 08-27-2008, 02:55 AM
Phil Ogden Phil Ogden is offline
There is up-datable firmware. If required, you're usually prompted the first time you launch PT (e.g after an update). However, there is also a way to force the unit into update mode manually. Here's how it's done on a 003 (see link below).
http://duc.digidesign.com/showthread.php?t=225512
http://www.myspace.com/philogg
Old 08-27-2008, 08:54 AM
DigiTechSupt's Avatar
That would seem to indicate there's nothing wrong with the 002.
Which version of Pro Tools do you have installed? Which OS version are you running?
Have you tried launching from a new admin account?
Avid Audio Tech Support
Support FAQ
Old 08-27-2008, 10:20 AM
Greetings Dougfather,
Thanks for the suggestion!
I'll check out the serial number for good measure but I'm pretty sure the symptoms I'm experiencing aren't the power harness issue as I have no issue using the 002 with a different physical computer (same OS X versions). I'll read a little more about it and if worse comes to worse, I'll give Digi a buzz for some troubleshooting help.
Hi Phil,
Thanks for the 003 info - I'll definitely research the 002's ability to reset the firmware if this something the 002 is capable of :)
Good looking out!
To DigiTechSupt,
I have PT 7.4.2 on Mac OS X Leopard 10.5.4 with combo and auto updates.
I am going to double check permissions on the default admin acct I'm currently using; perhaps I'll create a new acct w/ admin rights and see what happens
Thank you everybody for the helpful hints - more heads are better than one (and that one is really frustrated
I have a few more techniques I'm going to try and will update soooooon
Cheers,
Niko
Niko Bradway
002 connection issue Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-22-2014 09:45 AM
Digi 002 Connection issue Cre8Vsol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-24-2012 05:15 AM
Mbox2 Pro - Connection issue Megnus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-04-2010 02:32 AM
Connection issue with 002R and FW 800 Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-15-2010 12:15 PM
Mbox connection issue... XP borednbuzzed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-12-2003 06:32 AM
