Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-29-2006, 04:29 AM
nickpell nickpell is offline
Default M-Audio Firewire 1814 can\'t see 8 inputs
I just upgraded to the 1814 interface, downloaded latest drivers pluged in, fired up and Pro Tools sees the interface but I only get inputs 1 thru 4. Where are 6 thru 8?
I'm also hoping to use the adat lightpipe output on my old MOTU 828 to expand my inputs.....is this do able? Again when I look in the I/O section under setup in Pro Tools the digital inputs and unbalanced analogue ins 4-8 aren't available.......
I'm really new to Pro Tools apologize in adavance if this is a redundant question and would really appreciate some help.
Rick
MacBook Pro
OS X 10.5.1
2.16 Ghz Intel Core Duo
2 GB 667 Mhz DDR2 SDRAM
PT M-powered 7.1.1
Old 11-29-2006, 10:32 AM
DigiTechSupt's Avatar
Default Re: M-Audio Firewire 1814 can\'t see 8 inputs
Have you tried defaulting your IO Setups (Setups>IO Setups) for both input and output?
Can you give more info on your system - computer model, OS version, Pro Tools version, etc?
Avid Audio Tech Support
Support FAQ
Old 11-29-2006, 06:09 PM
Defaulting worked perfectly. Everything shows up....all good.
Thanks for taking the time to help. I can also see the inputs on my MOTU 828 via the adat I/O. This is killer.
FYI: Mac Book Pro v 10.4.8 2.16 Ghz 2GB ram PT v 7.1.1 M-Audio 1814 v 1.3.1 Driver 1.7.4 build 3
Firmware 2006-62-08-14:42:41-0600
Rick
MacBook Pro
OS X 10.5.1
PT M-powered 7.1.1
m-audio firewire 1814 daisy??? sethbrand Pro Tools M-Powered (Mac) 6 01-23-2016 02:32 PM
Newbie in need! How do I use inputs 3 - 8 on my M-Audio 1814? jhaxton Pro Tools M-Powered (Mac) 1 07-30-2009 08:26 AM
Accessing all inputs on M-Audio 1814 kevinc333 Pro Tools M-Powered (Win) 4 05-27-2009 08:49 AM
003 vs. M-audio firewire 1814 legacygone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2008 07:41 AM
M-audio Firewire 1814??? sethbrand Pro Tools M-Powered (Mac) 2 03-13-2007 10:55 PM
