How to install fresh OS?
I have an off the shelf Compaq that I am planning on installing a fresh OS on. This is to remove all factory installed software (plus adware and spyware). I was wondering how to best go about this. I have already backed up all of my files that I want to keep. Do I need to format my hard drive? If so, how do I do this and how do I then install the OS. Also, Should I get XP home or Professional?
Thank you, Alex
BigALW1414 |
Re: How to install fresh OS?
Installing Windows XP (Home or Professional) will offer you the option to reformat your hard drive in the process. Home will work fine unless you need the advanced networking capabilities of Professional. Professional is designed for creating and connecting to servers and domains where Home is better suited to workgroups and peer to peer networks. Both work equally well with Protools for audio purposes. To install the new OS, the easiest way is to set your CDROM or DVD as the first boot device (set in the CMOS settings) and simply boot from the Windows XP CD and follow the instructions. If you are worried about losing data, play it safe and use a different hard drive. Hard drives are relatively inexpensive nowadays.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
If you give Compaq a call at 800-652-6672 they should be able to walk you through the format procedure. Its not that hard with XP caus you pretty much put in your OS cd and boot from cd and delete any old partitions, format your drive....etc... If you had a lot of spyware/adware I would highly advise to format the drive to get rid of that stuff for safetys sake due to the fact that it imbeds its self into your computers registry and is a pain if you don't format.
Thanks for the help guys. I also have a 30GB 7200RPM hard drive from an old computer that I was considering using as the system drive. How do I go about hooking this up?
BigALW1414 |
I would get a firewire or USB box to install the drive in. You can then format it there, and install OS and so on. Afterwards put the drive in your laptop and use the firewire box for backups and so on. G.
Gunnar Hellquist true amateur |
Gunnar ,
I do not have any laptop experience...but remember (on desk tops) you can't use an external USB or FW drive to boot the OS from... good luck
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Fresh install...bad, bad, bad.... | gofortheheart | Windows | 5 | 09-03-2012 03:21 PM |
Clean install of PT 10 under fresh install of Lion | bortraws | macOS | 0 | 10-24-2011 08:53 AM |
Fresh install of LE 8 | Fezzler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-29-2010 12:13 PM |
PT8 fresh install | BlueThursday | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 02-12-2009 06:44 PM |
fresh install | halfguard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-08-2008 09:22 AM |
