Create a playlist from a loop already recorded
Hi all
I had to rebuild and reinstall, and after doing that forgot to check the magic box "automatically create new playlists when loop recording". I then spent a day recording takes using loop recording, with this box not ticked. Now I've come to the comping bit and I've realised there are no playlists there. Does anyone know how I can get Pro Tools to generate its playlists from these takes? I know one option is to manually create them, by using the Trim tool to extend the audio file and cut it up manually and drag them into the playlists. HOWEVER, it's a multi-bpm session, so if I use the trim tool to get access to the other takes, they will no longer be accurately snapped to the grid. Any ideas? Thanks in advance. Dicky |
Re: Create a playlist from a loop already recorded
I would :
select the clip on the recording track, which might be something like audio_01-05 open cliplist to see this selected clip recheck timeline drop order : from top to bottom make 4 new tracks or playlists on the recording track in cliplist select the 4 other ones (audio_01-01, audio_01-02, audio_01-03, audio_01-04) start-drag those onto the new tracks/playlists (while audio_01-05 is still selected in the edit window) alternatively : select the clip , right-click , match alternates , expand alternates to new playlists (tracks) (but : lots to do to clean up all the new playlists/tracks and move the alternates on less playlists/tracks)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 Last edited by joachim; 03-05-2014 at 06:53 AM. Reason: forgot alternative |
Of course! The clip list. I'll try that. Thanks so much for your help
Playlist Ordering when using Loop Recording | Alden | Pro Tools TDM Systems (Mac) | 2 | 03-18-2014 12:41 AM |
A way to create a new playlist when re-recording over playlist section? | jschmidtiii | macOS | 2 | 08-13-2013 02:28 AM |
Create a new playlist key command doesn't work for video. | reichman | Post - Surround - Video | 0 | 05-14-2011 06:12 PM |
New Playlist in Loop Record | jkatcher | Post - Surround - Video | 0 | 06-19-2006 02:13 PM |
Can you Loop Record to a Playlist? | remote | Pro Tools TDM Systems (Mac) | 0 | 05-19-2003 01:20 PM |
