Delay Compensation in "Playback Engine"?
Hey Guys,
I was watching the AVID video "Pro Tools 11 - The New Standard for Audio Production" and noticed in the video that the Playback Engine has the "Delay Compensation Engine" option available (see "PT 11 Playback Engine Pic 1"). But on my system there is no "Delay Compensation Engine" option (see "PT 11 Playback Engine Pic 2"). Is this option only available to HD users? I went through the manual but didn't see any info regarding this. Just getting into PT 11 so I'm not used to some of the changes from PT 10. Many thanks! MacBook Pro 15-inch with Retina display (Early 2013), 2.7 GHz Quad-core Intel Core i7, 16GB SDRAM, 512GB SSD, Mountain Lion (10.8.4), Pro Tools 10 (10.3.7), Pro Tools 11 (11.0.1), Apogee Duet 2. Last edited by RokVox; 09-10-2013 at 02:57 PM. Reason: Typo... |
Re: Delay Compensation in "Playback Engine"?
Anybody?... Would greatly appreciate the help!
i can´t see that option as well!
edited: i think the ADC is in auto-mode now! No need to worry, see what i found in the manual:
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Thanks my friend!
Yes, I saw this in the manual as well! Kinda confusing that it's shown in the AVID presentation video, yet it's been removed from the "final release"?!? http://www.youtube.com/watch?v=XCJj_J05l9E Moving on... |
Agreed. The video was probably made with a pre-release version.
Thanks Chief!
Good riddance. I see no reason to have the Off/Short/Long/Maximum setting. Much better if it scales to the longest delay automatically. I'll just monitor in the mix window, and keep my eye out for red...
...Which hasn't happened yet. AAX has performed much better than RTAS, in everything I've done. We'll see when Izotope Ozone gets ported over - the maximizer with lookahead and MBIT+ dither really took a bite out of CPU in Pro Tools 10. |
Already ported! http://www.izotope.com/products/audio/ozone/support.asp |
They almost beat Avid's release date, even. Good on you, Izotope. |
"The current playback engine does not support a sample rate of 48 KHz" error when tr | eyeshow | Pro Tools M-Powered (Win) | 19 | 09-09-2015 10:10 AM |
Focusrtie SP40 missing from "playback engine" list | burningjoe | FireWire & USB Audio Interfaces (Mac) | 4 | 03-25-2014 03:04 PM |
is there "delay compensation" for writing automation via faders?? | anotherchrisperry | Artist Series | 19 | 10-01-2012 05:45 AM |
"The current playback engine does not support a sample rate of 48 KHz" | E-Lister | Windows | 3 | 02-25-2012 11:54 AM |
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 | beasleymusic | Pro Tools M-Powered (Win) | 1 | 04-02-2011 03:17 PM |
