Old 11-13-2008, 05:33 AM
THE KAMEN BIZ THE KAMEN BIZ is offline
Angry Robot sound when recording vocals
IM JUST GETTING STARTED USING THE 7.4 SOFTWARE....I HAVE THE MBOX2 PRO NOW AND IM A BEGINNER WITH PROTOOLS BUT NOT NEW TO RECORDING.... BUT WHEN I RECORD VOCALS USEING PROTOOLS IT MAKES A ROBOT/ECHO SOUND DURING THE PROCESS... HOW DO I FIX THIS PROBLEM
Old 11-13-2008, 05:59 AM
The Dougfather The Dougfather is offline
Default Re: Robot sound when recording vocals
Sounds like latency.
As you have the pro you can select low latency monitoring, bottom of one of the menus, can't remember which???
Or, if you want FX, drop the playback buffer as low as your system will allow. LLM is much safer.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 11-13-2008, 06:14 AM
JonesH JonesH is offline
you can also adjust the playback balance on your MBox between "playback" (the delayed signal from pro tools) and "input" (what goes into the mic pre). Most likely you have the setting somewhere in the middle, combining non-time aligned signals wich introduce the phasing and robot fx sound you're hearing.
I just wanna do engineering...
(as opposed to make music :/ )
Old 11-13-2008, 07:11 AM
Phil Ogden Phil Ogden is offline
I think the mix control that you refer to is specific to USB Mboxes. The OP has the Firewire equipped Mbox Pro.
http://www.myspace.com/philogg
Old 11-13-2008, 08:49 AM
RussUK RussUK is offline
Yes it latency, we all battle with it in one way or another.
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 11-14-2008, 04:04 AM
Talking Re: Robot sound when recording vocals
thanks guys... I apreciate it....it worked:d
After recording vocals, there is no sound during playback. Why? sfwdslashx Pro Tools SE and Essential (Win) 8 10-25-2012 07:21 PM
Mbox2 Win7 64bit - Robot sound RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-03-2011 01:56 AM
Recording vocals - sound dry in song. Help with EQ, etc Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-22-2009 10:02 AM
Robot sound when playback or punching in Parisstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-19-2005 03:05 PM
Lo-Fi sound on vocals hmccabe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-08-2002 06:52 PM
