Old 12-15-2015, 09:18 AM
improvpwnd improvpwnd is offline
Default Re-writing mod wheel/MIDI automation
Is there a way to completely overwrite midi automation so I don't get these crude jumps when I do a second pass at MOD wheel automation (for example?)
File Type: png Screen Shot 2015-12-15 at 9.16.10 AM.png (14.3 KB, 0 views)
Old 12-15-2015, 09:32 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Re-writing mod wheel/MIDI automation
You can use the selector tool to highlight the area in the automation lane you want to overwrite, then hit backspace, and it will erase it, then write in a new one. Also, if you turn off MIDI merge, then new MIDI data will overwrite rather than add. That may be what's happening here.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2019.10
Focusrite Scarlett 8i6
Old 12-15-2015, 09:41 AM
Ah, MIDI merge makes sense.. I understand I can delete and re-write, but I wanted an overwrite solution. I see how it defeats the purpose of MIDI merge though.
Old 12-15-2015, 12:09 PM
midnightrambler midnightrambler is offline
Not much good though as you'll lose all your midi notes as soon as you take midi merge off....
Old 12-15-2015, 01:11 PM
studiostuff studiostuff is offline
Open another MIDI track (track two) with the same output target.
Make a selection of the problem area on the first MIDI track mod wheel data.
Erase the selection area on track one.
Enter record on track two and just perform the mod wheel (with MIDI merge OFF) . And do it until you get a pass you love.
You can stop now if you don't mind the two tracks, or copy the good mod wheel data from track two and paste it into track one. Then, and only then, erase track two.
Writing automation without deleting MIDI notes lostsherb88 Virtual Instruments 1 11-28-2011 05:32 PM
RTAS Instrument Automation Writing From Midi Controller tekk Pro Tools 9 4 08-04-2011 10:46 AM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 02:41 PM
MIDI - PT Mod Wheel automation recording smlworld MIDI 2 06-07-2007 05:48 AM
writing plugin automation with remote MIDI controller pcl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-16-2003 12:27 AM
