Old 01-31-2020, 09:38 AM
fiddlecat's Avatar
fiddlecat fiddlecat is offline
Default Low-end graphics card?
Can anyone recommend a low-end (inexpensive) graphics card for my windows-based system (Asus P9X79 MB, i7-3820 CPU)?
This is not a Pro Tools, issue which is running fine. It’s a Windows 10 issue. When I put my system in “sleep” mode, I will often get a crash dump blaming my graphics card (ATI Radeon HD 4300/4500 series). There are no driver updates for this guy so I’m thinking I need to get something newer that is supported.
Again, my overall PT performance is perfectly adequate as-is, so most any newer replacement will work as long as it gets along with PT.
Pro Tools 2023.6 & 10.3.0
Windows 11 Professional / 64-bit
Roland Octa-Capture
Old 01-31-2020, 10:13 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Low-end graphics card?
I run a GeForce 1050 based card in my Windows 10 system and have not had any issues.
You can pick them up int the $150-$180 range depending on the maker.
Will
System Details
Old 01-31-2020, 10:37 AM
The Weed's Avatar
The Weed The Weed is offline
"When I put my system in “sleep” mode..."
One of the optimizations Avid recommends is to never let your computer sleep or hibernate. Have you done all of the optimizations? Before spending any money, have a look at this thread and do ALL of the optimizations recommended.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-31-2020, 12:51 PM
EGS's Avatar
EGS EGS is offline
I'm using this NVIDEA card, & it actually drives my triple-monitor setup (edit/mix/misc) surprisingly well: https://www.newegg.com/evga-geforce-...82E16814487219
Click for audio/video demo
Click for resume
Old 01-31-2020, 01:09 PM
fiddlecat's Avatar
Thanks for the suggestions, I will look into them.
But just to be 100% clear, I am not looking for help in debugging or optimization. Pro Tools is working just fine. I merely want to upgrade the graphics card to something newer that will play nicely with PT and Windows 10. Doesn’t need to be fancy – I run small, low intensity sessions. Just needs to work reliably…
Roland Octa-Capture
Old 01-31-2020, 09:11 PM
fiddlecat's Avatar
EGS ---
Thanks for the recommendation. Looks like exactly what I need. The latest driver update was earlier this month, so I should be good to go for a while...
Roland Octa-Capture
Old 02-01-2020, 09:02 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by fiddlecat View Post
EGS ---
Click for resume
Graphics card on the way out?? Raoul23 General Discussion 4 07-16-2018 01:52 PM
EMI Noise: Graphics card to HD Native card jacknprewitt Pro Tools HDX & HD Native Systems (Mac) 0 10-19-2013 09:02 PM
HD Native Card Possibly Fried My Graphics Card witrelo Pro Tools HDX & HD Native Systems (Mac) 1 09-14-2011 11:46 AM
Graphics card for PT hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-07-2007 12:09 PM
Graphics Card reyalp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-30-2004 11:17 AM
