Need help with C24 connections!!
I am new to Pro Tools and just purchase C24, 192 (Digital only), Avalon pre. I have 2 mains, 2 monitors, 1 sub that I need to connect. I have PCI expansion chassis with HD core & accel running pro tools 10 on 2.66 intel Mac Pro. Can someone please tell me how to connect this setup? Thanks
Re: Need help with C24 connections!!
You are sort of hosed by the 192 being digital only. Your preamps(the Avalon and the 16 in the C24) are all analog, so you need a way to get analog into Pro Tools. I would sell the 192 digital and buy the analog version, or the newer HD IO 16x16. Once you have the correct combination of gear(and the cable package that goes with the C24), its signal routing 101
the reply above is absolutely correct in that.
You do not have any analog inputs or outputs. The digital i/o is unnecessary in your rig at this time. Swap it for a analog 192 or buy a 192 ANALOG with 16 ins 8 outs. Or if you are trying to save some cash two 96i/o 8ins/outs on each of them. not the 8in and 2 out model High quality cables really make a difference so dont cheap out on those. It is often the biggest improvement a studio can make and its very affordable no $49.99 cables The digidesign cables are a good trade off of quality vs cost if bought used. You are probably confused because you did not understand the digital converter wont work with analog . But once you have what you need its no different than connecting a guitar to a amplifier . Output goes to input and vice versa |
Connetions connections connections | Maxaudio | General Discussion | 3 | 09-28-2011 08:50 AM |
Connections? | Mainstream | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-23-2011 05:58 PM |
5.1 PC Connections | Touchwood Studios | ProControl, Control|24, Command|8 | 2 | 11-18-2008 02:19 AM |
Need help with 192 i/o AES connections | losttimestudios | Pro Tools TDM Systems (Mac) | 3 | 08-16-2004 03:13 PM |
TDM Connections ??? | Suz | General Discussion | 1 | 09-17-1999 05:22 PM |
