Old 05-26-2007, 02:36 PM
jrmintz jrmintz is offline
Default Weird master fader issue
Has anyone experienced this: I have a fade programmed on a master fader at the end of a song but sometimes the level doesn't change. Automation is in read, the fader moves, but the level doesn't change. If I grab the fader with the mouse and move it the level changes. I've tried turning auto read off and back on - no difference. I just restarted PT and no difference. I really don't have a clue. If I rebooted the computer it might be better or it might not. Any body know why this might happen?
Thanks,
Seth
I'm using PTHD 7.3.1CS2 on a dual 2.5 G5 with 3.5 meg of ram
Old 05-26-2007, 03:46 PM
Drew Mazurek's Avatar
Default Re: Weird master fader issue
Is automation Suspended?
www.drewmazurek.com
Old 05-26-2007, 10:42 PM
Andre Knecht Andre Knecht is offline
Is the master fader in question actually controlling the path which you are monitoring/printing?
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 05-28-2007, 06:35 PM
Thanks guys,
I'm not sure if it's suspended, I'll take a look. The master is definitely on the audio path I'm listening to, otherwise why would it work when I grab the fader and move it manually?
Seth
Old 05-29-2007, 08:38 AM
The automation is definitely not suspended - If I grab the fader during playback and move it manually the level changes and, when I let go, the fader and the level return to the preset level. I trashed the prefs and the DAE setup and the other stuff. What could do this?
Thanks,
Seth
Old 05-29-2007, 09:20 AM
DigiTechSupt's Avatar
Is this happening in every session or just this particular one?
If it's just one, it could be session corruption. Either way, you may want to delete that fader and create a new one, which may help.
Avid Audio Tech Support
Support FAQ
RT Sac-2k master fader issue midKnight Pro Tools M-Powered (Win) 1 01-08-2010 01:10 PM
ADC and Master Fader Issue wyman Pro Tools TDM Systems (Mac) 21 01-21-2008 01:28 PM
weird, loud POP and no audio on master fader! guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-13-2008 07:35 AM
Weird master fader problem Nutsville Noise Lab Post - Surround - Video 3 11-29-2005 01:19 PM
weird master fader issues... Ken P Pro Tools TDM Systems (Win) 5 01-29-2005 08:51 AM
