#31
Re: Autotune Pro Out
Yes
#32
Sent from my SM-N950U using Tapatalk
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. |
#33
what's up with the offensive update reminders? I have to constantly open older sessions and get about 10 reminders / day about a new "update", which is actually an UPGRADE for Pro. really bad manners imho...
#34
Are you having the same issue? My problem was a Mac issue and it looks like your on Windows.
#35
Antares just released update 9.01 with bug fixes.
#36
hi
can anybody tell me that,, im new in protools hdx ,, but auto tune don’t have aaxdsp right, So it’s mean I can’t use auto tune on protools hdx now?? Or I still can use it when I running hdx ? Just this plugins not going through hdx card , is running by computer cpu? And what is the problem will happen if I doing that way?? Thanks a lot,, |
#37
if you want to record through Autotune use a Trim plugin as DSP in the first insert and then Autotune after it.
It might help to bring down your H/W Buffer Size in the Playback Engine settings. You will have latency, no way around that. Try to minimise it by making plugins on your Master channel inactive. If it is for mixing ignore the above and just load up Autotune and don't worry about it. |
#38
so if I just use it for mixing is totally fine? How about others plugins like waves? I didn’t using auto tune during recording before, but if the singer need to do this , I heart that there is a auto tune live include in the pro version. Can that one solve the latency problem? If not so I need to reset the buffer size when I use it? |
#39
If you want to record with it live, activate the low latency setting in Autotune Pro settings. I would also use low latency monitoring in Pro tools and try to use a buffer of 128ms or less. Hope that helps.
Mac Studio M1 Max Apollo X6 MacOS Ventura |
#40
so I can purse the autotune pro ,hah,, do you use the hdx system also? I just found only few brands are doing aaxdsp version,, not so many choice... but if I use another plugins that means I using computer cpu to running right?? thats kind waste of the dsp lol ... |
autotune vs melodyne,.. (looking for keyboard input feature in autotune,..pls help..) | heidib123 | Getting Started | 4 | 07-06-2017 12:31 PM |
Autotune! | OfficialYoungDiz | Pro Tools M-Powered (Win) | 1 | 07-06-2009 09:54 AM |
I need autotune | shawnv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-03-2006 08:47 AM |
Best Way to use AutoTune? | sydphi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-07-2003 06:45 AM |
autotune for XP? | executivos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-14-2002 12:58 AM |
