Old 10-24-2018, 08:38 AM
digiot digiot is offline
Default Osx 10.13.3
So Avid still says the last aproved OS is 10.13.3
does anyone know where I can find an install for that. I can only find Updaters and combo updates for 10.13.3.
Still running 10.12.6 here but I hate being 2 OS X releases behind
Thanks
Old 10-24-2018, 09:00 AM
TNM TNM is offline
Default Re: Osx 10.13.3
Thanks
check my topic with the link to the full installer of 10.13.2, then you can upgrade to 10.13.3
however most of us find that 10.13.6 is just fine with 2018
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 10-24-2018, 09:27 AM
TrackerLe TrackerLe is offline
The Problem with 10.13.6 low latency recording of more tracks with hdx does not work and result in error messages... And if you use audio tracks with input monitoring for using instrument tracks with heat cause 9173 and similar errors...but not in Sierra...
Which thread are refering to...
I use 10.13.6 and i want to go back to 10.13.3 with a new installation...thanks
Old 10-24-2018, 09:35 AM
TNM TNM is offline
sorry to hear it.
Avid are taking their sweet time to fix it but there have been issues with armed tracks in pro tools as far as i can remember, especially at low latency. it just doesn't perform like other DAWs, and all avid do is either blame plugin devs or apple. It's really frustrating.
Old 10-24-2018, 10:06 AM
Cacov's Avatar
Cacov Cacov is offline
For me it runs with the same performance on 10.13.3 and 10.13.6, buffer sizes under 128 samples are non useable. A least on Vanilla PT.
In any case, if anyone needs a 10.13.3 full installer, I have a .torrent I can share. PM me.
macOS Mojave | Avid Pro Tools Duet, Apogee Groove & Symphony I/O | Pro Tools Studio 2022
Sound Engineer | Non-Avid Employee
Old 10-24-2018, 10:11 AM
JFreak's Avatar
JFreak JFreak is online now
shhh... we don't want to talk about torrents here...
Janne
Old 10-24-2018, 10:16 AM
Cacov's Avatar
Oops I didn't mean that, I meant another err.. hmm. Well good luck finding the 10.13.3 installer !!!
PS: FWIW, regarding low buffer performance (cpu spikes and errors) I tried all the supposedly best builds from PT 12, here is my report: 12.4, same, 12.7.1, same. 12.8.3, 2018.2, 2018.7 and finally 2018.10 all the same. So... 2018.10 seems to be the keeper atm, while no improvement in that area.
Old 10-25-2018, 12:23 PM
clutch clutch is offline
I recently got in touch with Apple support to see how to get a machine back to 10.13.3.
They said the official way is to do a fresh install following instructions from here and then install the 10.13.3 updater from here.
He used to cut the grass...he was a very nice boy...
Old 10-26-2018, 03:47 AM
GTBannah GTBannah is offline
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 10-26-2018, 03:49 AM
.... in the mean time, I see notices about "Mojave".
Should we "desert" it?
Derrkins
GuyBarTola
